Author Topic: Jobber j200  (Read 528 times)
Offline JesseA
Jobber j200
« on: March 10, 2019, 09:18:34 AM »
Dad and I went halfsies on a j200 some time ago after doing lots of inefficient milling with an Alaskan.
And itís been a bunch of trouble. Mostly related to breaking blades.  Anyone have one of these to suggest pointers?
Offline hamish
Re: Jobber j200
« Reply #1 on: March 10, 2019, 11:29:35 AM »
How or at what point are your bands breaking (ie comming off the bandwheels? in the cut? out of the cut?).
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
Offline JesseA
Re: Jobber j200
« Reply #2 on: March 10, 2019, 04:49:41 PM »
Itís been a while since I used it but it seems like they break in the cut at random and are not being thrown off.  I wonder if whatís happening is weíre compensating for not great alignment with too much blade tension.
Offline Southside
Re: Jobber j200
« Reply #3 on: March 10, 2019, 05:19:05 PM »
How dull are your bands when they break? Running high tension, no lube, and dull bands will cause a lot of heat and stress cracks in the band, which will result in breaking.
Offline barbender
Re: Jobber j200
« Reply #4 on: March 10, 2019, 05:52:20 PM »
We need way more specific info to help you diagnose this problem. There's lots of things that can break blades, from running them dull to a bad band wheel bearing and everything in between.
Offline hamish
Re: Jobber j200
« Reply #5 on: March 11, 2019, 08:13:15 PM »
Get your alignment in order and adjust your tension accordingly. I have seen J200's produce alot of bf of lumber so the lack of band lubrication on the mill is a non issue.
Jobber J-200 saw mill
Started by mad dog on Sawmills and Milling
Last post September 02, 2014, 11:58:04 AM
by woodshed
