Author Topic: Anyone want to talk about Belsaw Mills  (Read 5566 times)
Offline jimparamedic
Re: Anyone want to tal about Belsaw MlLLs
« Reply #20 on: March 30, 2019, 07:49:12 AM »
I am using an old 14hp engine I am also only cutting with 24 teeth Ill try and find a pic of my power unit.
« Reply #21 on: March 30, 2019, 08:05:44 AM »
My dogs have a long and a short spike works good. but have been thinking about making some kind of slide hammer to set and remove the dogs
« Reply #22 on: March 30, 2019, 11:44:24 AM »
Babylon519  was looking at your photos and seen your planer looks a lot like mine
« Reply #23 on: March 30, 2019, 11:45:57 AM »
Also in this pic is the 14hp motor I am now using to run my belsaw
Offline Trapper John
  • Location: Galena, Ak. 200 miles west of Fairbanks on Yukon River
  • Trying to learn circle milling
« Reply #24 on: March 30, 2019, 01:19:38 PM »
Babylon, I have had saw heating but it was caused by loss of rpm in the cut.  By the way I have found shims (5/8" ID X 1" OD) on Amazon.  Let us know if you try shims and if that solves your heating issue but I would check track alignment first.  For setting and releasing my dogs I use a machinists hammer.
« Reply #25 on: March 30, 2019, 02:07:12 PM »
Lead out, teeth not sharped straight or swaged heavy to one side, feed to fast, bearing going bad, holders for teeth loose, also a combination of these. And another thing I've seen is trying to run a left hand blade on a right hand mill or vice versa. In all my trial and tribulations it is usually a combination of things that by then selves would not cause a problem.
Offline moodnacreek
  • Sawin by the notches
« Reply #26 on: March 30, 2019, 08:23:10 PM »
Don't see how anybody could saw with 14hp even with only 24 tooth and 1" feed. Years ago I sawed with 32 teeth and 25 hp, just barely.
« Reply #27 on: March 31, 2019, 03:25:12 AM »
I did not think it would saw either but when I got the mill I wanted to get every thing adjusted and working while looking for a 4v Wisconsin. It was running good so I throwed a log on and off I went.
Offline BUGGUTZ
  • !wen m'I
« Reply #28 on: March 31, 2019, 08:33:55 AM »
I'm running a small block Chevy and sometimes I don't feel like that's even enough. I have a 6bt Cummins sitting here, if I could only afford a PTO clutch for it!
Everyone has to be somewhere.
Offline moodnacreek
« Reply #29 on: March 31, 2019, 08:54:22 AM »
If you have the sae flywheel I may have the clutch.
Offline moodnacreek
« Reply #30 on: March 31, 2019, 08:56:58 AM »
Just took a 4cyl. Wisconsin off my slabwood saw.
Offline bandmiller2
« Reply #31 on: March 31, 2019, 08:38:50 PM »
Its pretty much how fast your sawing, a small engine will worry its way through. Years ago I was doing some sawmill bumming, the sawyer was greased lightning but only had a international gas four cylinder tractor engine. He was always waiting for the engine to catch up. A proper diesel, I bet his output would have jumped. Frank C.
« Reply #32 on: April 01, 2019, 03:24:37 AM »
Today I inspected and wire brushed an old 43" saw I had lying around.  I am running a 48" saw now but I don't know if that is a good idea so I want to try this smaller saw.  It is missing 13 shanks and the teeth really varied in length and were poorly filed.  It appears the old girl had a hard life.  I put a straight edge on it and it appeared pretty flat in both planes so I guess its worth a try after I replace the missing shanks and install new teeth.  The shanks are stamped 3-8 so I assume its a 3 tooth and 8 gauge.  When a saw is referred to as a 7/8 saw, does that mean the saw is 7 gauge at the center and 8 gauge at the rim?  You guys might find it interesting to know that Belsaw apparently sold some of their sawmills with a 48" saw.  The 48" saw that came with this mill has a 1 3/8" ID and B-9 shanks just like their standard 40" saws.  As far as the carriage creeping backwards in a cut, I solved that problem (I think) but pushing the set lever all the way back against that rod that helps support the knees.  No way it can move backwards.  I have a problem with the dog board.  I can't make anything less than about 2".  The dogs are in the way.  Is this normal for Belsaws?
Offline Don P
    • Calculator Index
« Reply #33 on: April 01, 2019, 07:11:50 AM »
Mine came with a 46" blade standard, a Timberking M-14... a Belsaw. If the pawl is engaged and the pull handle is back it is pretty much locked. The plate that is under the carriage below the headblocks should also be snug but if the cant is pushing you aren't tuned in yet, usually that means the lead is off or the track has a problem. I have to keep an eye on the inside loading end of mine, it gets pounded down and puts it in a twist.
I have a 1x2 leaning up on the loading opening post that I throw behind the cant on my last turn to space the cant out 1" which allows a 1" dog board. I also use it on top of boards when edging to avoid putting dogging marks into my boards. apm built a tube steel frame 1" thick that bolted across his blocks that did the same 1" spacing out. I'm running a tired old TO35 with 15 teeth on the blade. I do have apm's 6 cyl deutz I need to get the round tuits and hook up.
Offline moodnacreek
« Reply #34 on: April 01, 2019, 07:22:29 AM »
2 inch is the last board thickness unless you modify like I did. Unless made flat saws are 1 or2 gages thicker in the middle and flat on the board side. That is the reason for l/h and r/h saws. Belsaw once made a sawmill [larger mandrel] that took up to a 52" saw. Sawmills don't really come with a saw. You put on what you want or can find within reason.
Offline moodnacreek
« Reply #35 on: April 01, 2019, 08:44:55 AM »
2 inch is the last board thickness unless you modify like I did. Unless made flat saws are 1 or2 gages thicker in the middle and flat on the board side. That is the reason for l/h and r/h saws. Belsaw once made a sawmill [larger mandrel] that took up to a 52" saw. Sawmills don't really come with a saw. You put on what you want or can find within reason. Messed that up, ment flat on log side.
Offline Babylon519
  • Circle Sawyer
« Reply #36 on: April 02, 2019, 04:27:37 PM »
I run the saw with my 38 hp diesel IH B-275 tractor direct from the PTO. Mine has a 42" blade with 32 inserted teeth (2 are missing). TrapperJohn, I've been looking around for a 60 hp power plant, hoping that will keep the RPMs up when I'm in the wood as that is, for sure, one of the reasons the blade warms up. It seems like I'm usually cutting sawlogs that have been down for awhile, and they can be tough. A month ago, I cut some fresh-felled cherry, and the saw did a beautiful job of those logs. I think I want to cut more fresh, and less dead! :D BTW, that last board will be a minimum 2" thick too, thanks to the dogs being in the way.
JimParamedic, is your planer still working? Mine is a 24" monster that runs with flat belts back to a PTO pulley. For a 100-year-old machine, I'm amazed at the trueness of the spindle and the way it whirrs - it's still a precision machine. Wish I could find new 24" blades for it; the existing blades have been sharpened to the point I'm not comfortable taking them down any further. The feed roller is pretty worn too.   - Jason
Jason
1960 IH B-275 - same vintage as me!
1960 Circle Sawmill 42"
Stihl MS440 & a half-dozen other saws...
« Reply #37 on: April 02, 2019, 06:26:04 PM »
Jason,  nice looking planer.  My blade heat is caused by lost rpm when my 8" flat belt starts slipping at the engine.  I can saw but only with liberal application of belt dressing (corn syrup or honey).  I am looking into going to a 10" flat belt with idler if its not too expensive getting one up here.  By the way, an old time sawyer (82 years) in Tok Ak. said Belsaw sold heavier mandrels for the m-14 sawmill.  He said they were having too many complaints with the 1.75" mandrel and offered a heavier one.  Has anyone ever run across one of these heavier mandrels and what size were they?
The 60 hp should work OK.  Two years ago I was running a 40 hp JD crawler on my mill with the 48" blade and it would cut, but slow.
Offline moodnacreek
« Reply #38 on: April 02, 2019, 07:26:24 PM »
Fresh cut logs? Your darn right. There has always been so much hot air about keeping saw logs laying around. The only reason to do it is that you just can't get the time to saw them. Even a cut log a few weeks old is harder on the end than it was. In spruce the cut off knots get very hard soon. [try cutting back spruce or hemlock knots with a chainsaw and see]  And fresh cut logs make better lumber any way you look at it.
« Reply #39 on: April 03, 2019, 03:07:51 PM »
Babylon519  yes it is still going strong its a 20 inch. Also have a 24 inch that I want to get set up soon. A machine shop can make new blades
Belsaw mills
Started by bandmiller2 on Sawmills and Milling
Last post September 19, 2014, 04:27:12 PM
by Joe Lallande
Belsaw mills
Started by jimparamedic on Sawmills and Milling
Last post October 03, 2018, 08:11:55 AM
by moodnacreek
Belsaw mills
Last post May 17, 2014, 12:52:10 AM
by jimparamedic
Belsaw mills
Last post February 08, 2009, 08:35:35 AM
by Joe Lallande
