Author Topic: Timber Harvester upgrades  (Read 1057 times)
Offline Brad_S.
Re: Timber Harvester upgrades
« Reply #20 on: November 07, 2019, 10:57:12 AM »
Just found this post while doing a search so my comments are probably outdated.
TH gas mills were factory powered by 24 hp Onan engines. A mill of that vintage has no doubt been repowered.
By their own admission at the time, TH setworks  were substandard. When I bought a second mill in 2002, I asked about equipping it with setworks. Everyone at the company knew me well because I would often saw for the lumber company that shared the Timber Harvester complex. They assured me I was much faster setting the head manually than the set works moved. When you get enough stick a time on the machine, you will find it is as easy as previously described above.
Offline tylerltr450
  • Trust me I run SAP and a sawmill
« Reply #21 on: November 07, 2019, 12:08:54 PM »
But we are all lazy and like to push buttons  8)
At least I am, hence why I am trying to work on building a new TH Setworks from scratch.
Timber Harvester 36HTD25 fully loaded
2006 Dodge 2500 first Auto to NV5600 swap, EFI Live Tune by me
John Deere Tractor
timber harvester
Started by mac37 on Sawmills and Milling
Last post April 27, 2018, 02:59:57 PM
by mac37
Timber Harvester ??????????
Started by Sawing Logz on Sawmills and Milling
Last post March 11, 2008, 10:23:23 PM
by Sawing Logz
Used Timber Harvester ???
Started by sprucebunny on Sawmills and Milling
Last post May 20, 2005, 07:38:52 AM
by sprucebunny
We got our Timber Harvester!!
Started by True North on Sawmills and Milling
Last post April 07, 2009, 06:42:18 PM
by petefrom bearswamp
