Author Topic: Air space needed with spray foam?  (Read 412 times)
Offline Tree Dan
  • I may be In Canada but my heart Is also In the U.S
« on: March 25, 2019, 03:34:41 PM »
A dehumidification type kiln 20 x 8 x 8
If the roof is flat could this be foam sprayed, with no air space like a sloped roof?
Or even if the roof has a slope with a steel roof, could this be foam sprayed with no air space?
I think it can, but Im not a expert on this...what's your thoughts on this?
Tree D
Wood Mizer LT40HD, Kubota KX71, New Holland LS150, Case TR270
6400 John Deere/with loader,General 20" planer, Stihl 880, Stihl 361, Dolmar 460, Husqvarna 50  and a few shovels,
60" and 30" Log Rite cant hooks, 2 home built Tree Spades, Homemade log splitter
Offline tacks Y
Re: Air space needed with spray foam?
« Reply #1 on: March 25, 2019, 03:48:58 PM »
I would, air space would mean ventilation also. It should keep the ceiling from raining condensation. This being said I do not always work to code.
Offline Southside
« Reply #2 on: March 25, 2019, 05:57:43 PM »
Make sure the foam is rated for the temperature it will be exposed to also.
Offline rjwoelk
    • countrysidefirewood
« Reply #3 on: March 25, 2019, 06:08:14 PM »
When we did the cabin I sheeted the roof, covered it with water shield membrane.
Strapped it then put my tin exterior roofing on.
Then the underside of the roof was spray foamed  with 4 inches.  This is called a cold roof. The attic is part of the interior of the cabin .
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
Offline offrink
« Reply #4 on: March 25, 2019, 06:47:40 PM »
My brother sells buildings. His advice when I asked him about this exact thing, even if it is code, how will you replace that section if it ever gets damaged? You canít exactly remove the steel roof panel without destroying the insulation.
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
« Reply #5 on: March 25, 2019, 08:24:14 PM »
I had a similar question when I had the metal roof replaced on my barn (hale damage claim).  The salesman's recommendation was to install vapor/condensation barrier under the new roof panels.  If I have spray foam done later, the roof can still be removed for replacement.  Otherwise, you have to replace the spray foam too, and that can be a big mess and quite expensive.
07 Timberking B-20, Custom-made log arch, 20' trailer w/ log loading arch, F350 SD flatbed dump.  Princeton piggy-back forklift.  Bobcat S250, Stihl 025C 16" and a Husqvarna 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says "He's sawin logs", I ain't snorin'.
Offline Mike W
  • Location: Boundary Washington - Right on the edge of the Northern Boarder
« Reply #6 on: March 25, 2019, 08:33:16 PM »
x2 Tom the Sawyer, can be done without issue if there is a membrane installed below the metal or other roofing and the spray foam insulation, can be of any moisture barrier material like Tyvek, asphalt felt or plastic sheeting to give you an isolation barrier between the roofing structure and the insulation.  if ever needed the material can be removed and replaced or repaired without disturbing the spray in insulation.
Offline Tree Dan
« Reply #7 on: March 26, 2019, 02:45:23 PM »
Thanks for the input guys...that's what I needed to hear.
I guess plastic on the walls in-between the foam and steel would be a good idea too,
just in case I drove the skid steer into the side walls ;D
Cheers
Tree D
Offline jimbarry
    • WoodchuckCanuck
« Reply #8 on: March 27, 2019, 07:07:52 AM »
I spray foamed the floors level to the floor joists because I put down a plank floor afterwards. The walls and ceilings I had sprayed full and enough to cover the studs.
Jim
2017 Nyle L200
8ft x 10 ft x 20ft bldg
3.5-4" 2lb closed cell spray foam, Demilec brand HeatLok Soya Spray Polyurethane Foam Insulation
Offline woodshax
    • Outdoor Vending Solutions
« Reply #9 on: March 28, 2019, 08:35:45 AM »
So.....I used to have a spray foam insulation company....and had to learn me all there is about the products and applications.    Never use .5 Lb open cell foam on a metal building....it is like a sponge.... Used closed cell 2lb foam.... it is a complete moisture barrier at 2 inches and that is all you should use in depth...it also adds 50% of the racking strength of a 5/8" plywood.... they use it in areas like Houston  and the foam roofs are intact after a hurricane and the building around them without it end up in the next county.   You could also use 3lb roofing foam... that they put on the exterior of building roofs to protect them from hail, water seal and give insulation......I would not worry about roof replacement.....it will outlast you....if it does not...you just cut out the section sheet on top and then refoam that section....it will be water tight if done right....... if you were doing the walls I would suggest skinning over the foam with metal sheets just as a protection against scorching....foam is just plastic and although it has about a 500 degree F cross over  (dont quote me on the exact temp)...it just makes sense......the roof....depending on the internal temp of the kiln should be fine
spray foam on a kiln wall ?
Started by Tom L on Drying and Processing
Last post March 21, 2014, 10:49:23 PM
by GeneWengert-WoodDoc
Spray Foam Kiln Insulation
Started by Tom the Sawyer on Drying and Processing
Last post November 01, 2017, 08:29:49 PM
by Cazzhrdwd
Spray foam roof insulation
Started by jdtuttle on Alternative methods and solutions
Last post January 02, 2017, 12:55:33 PM
by woodshax
Upgraded my sawmill shed with spray foam
Started by 123maxbars on Sawmills and Milling
Last post June 11, 2019, 02:22:08 PM
by Wudman
