Author Topic: New sawmill on the way!  (Read 1000 times)
Offline busenitzcww
« on: March 30, 2019, 11:59:56 AM »
Iíve been lurking here for a month or two and been reading a lot of the threads here, but figured Iíd introduce myself.
So, Iím a one man shop and my main gig is custom furniture and cabinets. I grew up on a farm and still help out during harvest time. Having access to farm ground means thereís access to trees as a lot of it is bottom/creek ground. In the past Iíve harvested quite a few oak,walnut, walnut and ash trees and had a local sawyer come mill them for me. Recently the farm purchased some more ground that has a lot of timber, and some of it is ready for harvest. Also we got a escavator to clear some of the overgrown edges of the field. Some of the trees I cut are not the nicest sawlogs but I figured itís better than seeing them shoved into a brush pile. I thought about hiring someone to come out again but figured why not get my own mill and do it myself on my schedule. So I put in an order for a Wood-Mizer LT 15 wide 3 phs electric here about a month ago and hopefully theyíll have it done here in a couple weeks! I already have a rotary phase converter, so it will be a matter of running a new line to where my mill will be setup close to the shop.
I have a lean to on my shop that I cleaned out and added some gravel screenings to make it a bit more level for stacking my wood to dry. Iím also considering some sort of kiln in the future, both solar or powered, as I would like to make quite a few slabs. All in all Iím excited about the whole process and trying to plan things out ahead of time, so Iím sure Iíll have more questions before itís all said and done!  Jesse
Offline thecfarm
Re: New sawmill on the way!
« Reply #1 on: March 30, 2019, 12:16:56 PM »
Welcome to the forum. You will like sawing.
Offline dbroswoods
« Reply #2 on: March 30, 2019, 12:45:55 PM »
Welcome to the madness!!! Running a mill sure gets in your blood.
Thatís some fine looking Walnut. Should make some nice lumber and slabs😃😃
Offline Escavader
  • Sawmill/Planermill operator since1984
« Reply #3 on: March 30, 2019, 12:55:49 PM »
I'm running the electric lt 15 it's real nice it doesn't die down.you won't need the clutch with electric I just shut it off
Alan Bickford
Hammond lumber company/Yates American A20 planer with dbl profilers Newman feed table multiple saw trimmer destacker automatic stacking machine Baker resaw MS log corner machine  4 large capacity Nyles dehumidification kilns JCB 8000 lb forklifts woodmizer lt 15 and mp100 and blower
Offline Southside
« Reply #4 on: March 30, 2019, 02:07:26 PM »
Welcome to the Forum. Nice looking logs. Where are you located? The second picture suggests you are in the southern hemisphere.  :D
Offline jimparamedic
« Reply #5 on: March 30, 2019, 02:11:56 PM »
Welcome and enjoy. Just an FYI we love pictures
Offline donbj
« Reply #6 on: March 30, 2019, 02:16:16 PM »
That second picture. How do those logs stay on that flat deck without being strapped down?
Woodmizer LT40HDG24
Offline busenitzcww
« Reply #7 on: March 30, 2019, 08:27:34 PM »
Escavader, does your LT 15 have enough power? I was wondering if the wide model would have enough power or if I might want to go to a 15-20 HP motor down the road? Or maybe Iíll be ready to get a new/bigger mill by then. ;D
Iím from Whitewater, Ks which is close to Wichita. And yes, I think winter is finally over!!! Although we did have a few snowflakes this morning :-[
The logs are just sitting on the trailer, but there is 3Ē pipe on the outside edge. I only hauled them two miles and didnít feel like strapping them down so I just went slow and took my time.
Offline busenitzcww
« Reply #8 on: March 30, 2019, 08:44:21 PM »
Haha I love looking at other peopleís pics as well so here are a few more.
This is a oak log I pulled out of the creek. It seems halfway solid yet but Iím anxious to see how the inside really is. The hollow end only goes in a foot or so.
This is an ash log I cut down for a sawyer who also has a goat dairy. He said they were making racks to store the cheese, and needed a neutral/non scented wood, so as to not effect the cheese flavor.
A big hedge stump. Hoping to get some nice slabs out of this log. Stilh 661 + 36Ē bar
Found this hedge burl while cutting firewood one day. Iím not sure how I should process/use it. I ran it across the jointer a few times just to see under the bark.
Offline Mike W
  • Location: Boundary Washington - Right on the edge of the Northern Boarder
« Reply #9 on: March 30, 2019, 08:57:29 PM »
busenitzcww,
I own a LT15 Wide with the 25 HP, haven't had any issues with the power thus far, albeit the widest I have cut to date is roughly 32" cut, still performed as expected.  Not sure on the electric, but you should do very well with it, especially that you already have a RPC.
BTW, welcome to the FF, lots of good info and peeps here on this site I have found so far, although some are quick to give a bit of a ribbing here and there, all in good fun, we all do things that deserve a good laugh at by others one way or the other, in fact a thread was started about "did something dumb today" which I am sure we could all contribute to if not daily, possibly weekly if we are doing anything at all that is.  case in point donbj referencing the second photo of the trailer load being upside down, how the logs remained on said trailer. :D
Anyway, welcome again and keep the photo's coming, look forward to your post when you finally get the mill and up and running, making sawdust and possibly some boards to boot.  8)
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #10 on: March 30, 2019, 09:03:08 PM »
Mike,
  Remember he is using a 3 phase electric motor not a gas powered motor as I read his intro if that makes any difference.
Offline Crossroads
  • letís make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #11 on: March 30, 2019, 09:10:17 PM »
Congratulations and welcome to the forum
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator
Offline busenitzcww
« Reply #12 on: March 30, 2019, 10:54:49 PM »
L
ok, figured out how to orient my photos the right way! Sorry for aall of yo who were having to look at your screen upside down!
Offline Woodpecker52
« Reply #13 on: March 30, 2019, 11:10:32 PM »
Nice looking osage orange ( Original "yeller wood" trademark)!
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900
Offline busenitzcww
« Reply #14 on: May 13, 2019, 09:52:56 PM »
Finally got my mill home! Now to get it setup and make some sawdust. Problem is itís a little chaotic right now on the main business side of things :-\ and I wanna make sawdust tomorrow lol
Offline Crossroads
« Reply #15 on: May 13, 2019, 10:02:57 PM »
Congratulations
Offline busenitzcww
« Reply #16 on: May 15, 2019, 10:34:25 AM »
Cut my first log up last night! Had a small walnut I pulled out of the burn pile, and ended up getting a 7x7 beam out of it. It was fun just to play around and figure the controls out. First observation is the electric is sooooo quiet! Iíve helped tailgun for two other sawyers with gas, and hearing protection is just a must, but this thing just whispers! Got some cant hooks on the way as I found that moving/turning even a small log is a lot of work! Canít wait to play with it more but I got projects that need to get finished first  :-\.
« Reply #17 on: May 15, 2019, 12:38:04 PM »
If it will make a good 4x4 I run it through the mill I've got some nice boards that way. saves on splitting too
Portable Sawmill Special Deal - SAVE 10% on your Sawmill!
Started by HSV on Peterson Portable Sawmills
Last post March 10, 2015, 10:34:01 PM
by jamieotter
sawmill advice what is the best sawmill
Started by KY colonel on Sawmills and Milling
Last post February 24, 2017, 01:09:51 PM
by KY colonel
A sawmill's not enough ...
Started by Brucer on Sawmills and Milling
Last post June 02, 2010, 04:15:24 AM
by customsawyer
new sawmill
Started by sapsucker on Sawmills and Milling
Last post March 17, 2008, 06:16:46 AM
by sapsucker
