Author Topic: mustang problem  (Read 2299 times)
Online Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
Re: mustang problem
« Reply #20 on: April 07, 2019, 01:22:34 PM »
Jeff, I agree with the others that suggest you ditch the electric water pump. Unless the pony will only be a drag strip car that pump will just be a liability. imho.
mh
What all would I need to put it back together stock? I have no parts.
Offline moosehunter
  • Every once in a while
    • Saw it Coming
Re: mustang problem
« Reply #21 on: April 07, 2019, 08:54:19 PM »
Hopefully just a water pump and pulley and correct belt. The parts store should be able to help with bolts. The pulley you might find new but I'm sure you can find one in a scrap yard or online.
It could be much more complicated if the original accessories have been changed.
mh
If it is true that we learn from our mistakes, I must be Brilliant!
Offline doc henderson
Re: mustang problem
« Reply #22 on: April 07, 2019, 09:57:32 PM »
may need a new fan, poss. fan clutch and shroud to fit fan.  I would try to heat up the sensor to see if it comes on, with a heat gun or torch on the metal, with car off.  Or jump the pump and see if there is flow and or also jump the fan and let the car run.  If can idle and stay cool running then the cooling system is ok, just need to locate the sensor in a hotter spot. Does rock auto or similar carry those parts.  might at least have an exploded parts view and prices.  some used to need and extension to get the fan close to the radiator.  is it a serpentine belt? if so you may need a special pully or go back to v-belt.  Hate to ask, but have you had a follow up conversation with seller to see if there were any issues before?  Good luck
timberking B 2000, 277c track loader, PJ 32 foot gooseneck, 1976 F700 state dump truck, JD 850 tractor.
Offline thecfarm
Re: mustang problem
« Reply #23 on: April 08, 2019, 07:38:14 AM »
I bought a motor out of a van,300-6 Ford. I was swapping a V8 to this 300. I had a little bit of a hard time finding all of the brackets I needed for the swap, power steering, alternator and so on. Don't be shocked if parts are kinda hard to find.
Offline snowstorm
Re: mustang problem
« Reply #24 on: April 08, 2019, 07:50:08 AM »
ford parts .com this is the ford factory site not after market. i dont know if it will go back old enough to help you. it will have the parts drawing part number and list price
Online Jeff
  • Fearless Leader
Re: mustang problem
« Reply #25 on: April 08, 2019, 08:19:26 AM »
I think to begin with, it is going to stay electric. This is a hobby car. Fun car. I'll try to play with what is there, then go from there.  I though I had mentioned that I know the pump and fan both work.  With me new dialectical system I can easily isolate to run, or jump and run any of the add on electrical components.
Offline Hilltop366
Re: mustang problem
« Reply #26 on: April 08, 2019, 09:03:55 AM »
and the one heater house port in there was plugged with red silicone gasket sealer.
This has me wondering. Was it intentionally plugged or excessive use of silicone?  Could there be more in the system?
Online Jeff
  • Fearless Leader
Re: mustang problem
« Reply #27 on: April 08, 2019, 10:39:32 AM »
I think they just had a little too much around the hole, and it squished into the opening. The only issue to begin with was the fan didn't kick on at temp. It didn't overheat that I know of. Its only been tested setting idling, so without a fan, its boaund to eventually get to warm. Going down the road I figure it would have been fine.
waiting for the housing
Online Jeff
  • Fearless Leader
Re: mustang problem
« Reply #28 on: April 08, 2019, 05:37:41 PM »
Offline millwright
Re: mustang problem
« Reply #29 on: April 08, 2019, 08:48:20 PM »
Run a manual switch, then just watch the gauge and turn it on when you need it
Online Jeff
  • Fearless Leader
Re: mustang problem
« Reply #30 on: April 08, 2019, 08:51:28 PM »
I could do that, but then i would have to watch the gauge and turn it on when i need it. :D
Offline luap
  • Not as good as I once was
Re: mustang problem
« Reply #31 on: April 09, 2019, 02:30:03 PM »
I had a similar problem on an engine that the electric fan would not come on but fan was factory, not aftermarket. The problem was solved by installing a thermostat with a lower temperature rating. I think it had a 195  deg thermostat and I switched it to a 185 deg. Don't know if this would apply to your situation.
Offline luap
Re: mustang problem
« Reply #32 on: April 09, 2019, 08:25:14 PM »
mh
Google uneedapart. Online salvage yard network. Enter your vehicle information and parts you need. Individual yards will respond back with price and shipping cost. Some respond right away, others might take a couple of days
Offline Old Greenhorn
Re: mustang problem
« Reply #33 on: April 09, 2019, 08:32:10 PM »
Jeff, did you put the new manifold on with the sensor port yet? I am hoping this will change the dynamic and you might learn something more. If you did, curious to hear what you learned.
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) I mill for fun and my mental health. NYLT Certified.
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here.
Online Jeff
  • Fearless Leader
Re: mustang problem
« Reply #34 on: April 09, 2019, 08:46:39 PM »
Ive not been able to get back to it yet. Lots of yard work to get done and a website to get together for a member.
Offline woodmaker
Re: mustang problem
« Reply #35 on: April 10, 2019, 09:37:11 AM »
I'm not sure about your problem but I do agree with the diagnostics of most other members. One thing I would add is that small block fords come with water pumps which turned in one direction when they had v belts ,and the opposite direction after they went to serpentine belts. I'm sorry that i dont remember which is which,and am not where my reference books are.
franklin q80,builtrite 40,husky 372,sachs dolmar 123, dozers,excavators,loaders,tri-axle dump trucks ,autocar tractor with dump,flatbed and detachable trailers, and 8  f350 diesels
Online Jeff
  • Fearless Leader
Re: mustang problem
« Reply #36 on: April 10, 2019, 06:33:07 PM »
The new thermostat housing with the new sensor port cured the issue. At 185 the fan kicks on.  I took it for an innitiation drive around the block.(holy crap)
When i got back, fan was off, and came back on after sitting at idle a couple minutes.
Seems to be good to go. On to whatever next needs attention.
Re: mustang problem
« Reply #37 on: April 10, 2019, 07:05:03 PM »
I had a feeling... Glad that solved it. ANd I bet it looks better too!
Online Jeff
  • Fearless Leader
Re: mustang problem
« Reply #38 on: April 10, 2019, 08:25:08 PM »
Pulled the mustang out on the pavement for the first time. At about a 5mpg roll i gave it about half peddle. It broke both back wheels lose. I heard wildflower yell Hey!!  I'm afraid I'm  heading for trouble. :D
Offline Southside
Re: mustang problem
« Reply #39 on: April 10, 2019, 08:37:24 PM »
Any idea how many ponies that baby is making?
mustang 442 skidsteer parts manual
Started by donny zoomzoom on Wanted
Last post April 25, 2010, 10:10:53 PM
by donny zoomzoom
Fix & Maintain Skidder Mustang & f350
Started by Mlamountain on Job Opportunities
Last post May 07, 2011, 03:59:55 PM
by Mlamountain
mustang 442 skid steer, comments?
Started by amberwood on General Board
Last post July 17, 2007, 11:19:11 PM
by Corley5
2005 mustang gt roush package
Started by red oaks lumber on For Sale
Last post August 06, 2014, 06:36:36 AM
by red oaks lumber
