Author Topic: Self made trailer title  (Read 1236 times)
Offline chet
Re: Self made trailer title
« Reply #20 on: April 23, 2019, 08:39:17 AM »
Since registration and plates are not required in Wisconsin for homemade trailers less than 3,000 lbs. gross vehicle weight, I wonder how that would fly for me to be towing a Wisconsin trailer in Michigan. :P
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
« Reply #21 on: April 23, 2019, 01:23:05 PM »
Most states have reciprocity agreements with adjoining states.  They would look at the plates on the power unit (the vehicle towing the unlicensed trailer) and, if Wisconsin, they would probably let it go.  But if you are making the case that the trailer is based in Wisconsin, and the tags on your vehicle are from Michigan, you would probably need your Wisconsin trailer title in hand to avoid a citation.  If they are not required to be licensed in Wisconsin, there probably is no title...  ding.
Kansas has a similar situation in that trailers (homemade, commercial, boats, etc.) under 2000 lbs. GVW, registration is optional.  Some stores even sell plates that state "Kansas Trailer, under 2000".  I would often travel to our farm in southern Missouri, Kansas tagged vehicle towing an unlicensed small trailer - never a problem (but I carried a copy of the statute in the glove box).  Although "optional", registering small trailers isn't very costly and they are a commonly stolen item so having a VIN on file, and an identifiable tag, may increase your chances of recovery.
07 Timberking B-20, Custom-made log arch, 20' trailer w/ log loading arch, F350 SD flatbed dump.  Princeton piggy-back forklift.  Bobcat S250, Stihl 025C 16" and a Husqvarna 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says "He's sawin logs", I ain't snorin'.
Kiln made from Semi-trailer
Started by hydeoutman on Drying and Processing
Last post April 10, 2016, 07:00:21 AM
by ScottCC
Has anyone made removable hitch for WM trailer?
Started by flatrock58 on Sawmills and Milling
Last post September 21, 2014, 02:16:09 PM
by flatrock58
moved
MOVED: Kiln made from Semi-trailer
Started by chet on Sawmills and Milling
Last post February 21, 2016, 07:07:32 PM
by chet
Norwood HD 36 home made trailer package
Started by Hallcliff1990 on Sawmills and Milling
Last post September 08, 2019, 07:58:49 AM
by terrifictimbersllc
