Author Topic: Looking to purchase a loper/ pruner that will last. Any suggestions?  (Read 454 times)
Offline pebbles57
  • Member*
  • Newbie
I am in the process of cleaning up and thinning out a 70 acre woodlot.
We had a major ice storm twenty years ago and I have been working on this since than.  There is a lot of pin cherry and wood vines that need to go.
Most of this is in the one to two inch range.  I have been using a chain saw, but I want to get a good set of lopers that can handle this chore.
I have already gone through a few tools, the blades break and the tools fail.
Any suggestions on a good quality loper that will do the job and last?
Thanks for your input!
Kevin Rock
Offline Logger RK
Re: Looking to purchase a loser/ pruner that will last. Any suggestions?
« Reply #1 on: April 24, 2019, 08:20:59 AM »
I've been pretty happy with a Fiskar's brand. Cuts pretty much what fits in it.
Offline wisconsitom
« Reply #2 on: April 24, 2019, 08:41:00 AM »
Pebbles,
AM Leonard used to carry a loppers originally made by an outfit called Sandvik/Pradines....whcih later became Bahco.  It was touted for years as their most popular model.  I remember not its number, but i can tell you, this little loppers out-cuts anything else I've ever had in my hands.....and that's a lot of pruning tools.
This item might now have morphed into an "AM Leonard" house brand....not sure.  Wish I knew what happened to that loppers.  Far and away, the best ever made, and not a big clunky one like many large-capacity ones are.  Slim and light-weight, easy to use.....had orange handles, nice narrow cutting head that fit into tight crotches with ease.
tom
Offline florida
« Reply #3 on: April 24, 2019, 03:58:30 PM »
I always carry lopers, a machete and a brush ax when I'm cutting vines and small briush. The lopers typically never get used. I find a sharp machete to be many times faster and easier.
General contractor and carpenter for 50 years.
Offline Brad_bb
Re: Looking to purchase a loper/ pruner that will last. Any suggestions?
« Reply #4 on: April 25, 2019, 11:28:12 AM »
I have a set of Corona lopers.  I prune the farm trees every spring.  Seem good to me.  I have sharpened the blade a few times using a scrap piece of wood and the sandpaper method.  You need a sharp blade for it to cut and long leave a thick string attached.  A dull or chipped blade will only be frustrating.
Offline WranglerSS
Stihl
Kubota L3240
Kubota RTV 900
Woodmizer LT28
Woodmaxx 8h Chipper/Shredder
Need suggestions/opinions on a small planer purchase
Started by Cypressstump on Drying and Processing
Last post June 29, 2012, 02:07:50 PM
by Overlength
Fairmont pole pruner question
Started by maple flats on Forestry and Logging
Last post August 12, 2010, 05:22:12 PM
by maple flats
New purchase
Started by lyle niemi on Sawmills and Milling
Last post October 26, 2014, 11:55:14 AM
by lyle niemi
Saw Purchase - What Would You Do?
Started by lxskllr on Chainsaws
Last post June 26, 2019, 06:19:01 AM
by lxskllr
