Author Topic: My mill is sick  (Read 4933 times)
Offline WV Sawmiller
    • Green's Sawmill Services
My mill is sick
« on: April 24, 2019, 09:04:37 PM »
   Went to saw a small order of tulip poplar 1.5 miles from home for a friend today and sawed a small log into stickers with no problem then about a 14-15 inch 10' log into 1X6's and my mill head started shaking badly when I got to the first rail, about 2' in the cut. I was using 7 degree doublehards then replaced with a 4 degree and basically the same thing. Called WM and checked a few things like power feed belt which first thing I had already checked. Finally I went to move the head by hand and noticed it was binding so narrowed it down some from that. I took the chain off this afternoon and the sprocket and shaft seem to be turning freely so I don't think it is the bearings in there or the bearing that holds the chain against the sprocket. I'm thinking it is one of the rollers or the cam follower bearings but they all seem to be turning. If one would just lock up I could figure the one causing the problem but they don't. When I push the mill it seems to start binding sooner when pushing toward the front than the back.
   Anybody had similar problems or any suggestions as to things to check? I have about 570 hours on the mill and the last issue I had was I replaced a drive belt due to a broken bolt. I don't see how that could cause the symptoms I am seeing as it does it when pushed by hand and not even running and with the chain and power feed motor/sprocket off the mill.
Offline Lawg Dawg
  • True South Sawmill Lumber
Re: My mill is sick
« Reply #1 on: April 24, 2019, 09:09:29 PM »
How many years you been running this mill with no problems?
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
 John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Re: My mill is sick
« Reply #2 on: April 24, 2019, 09:20:11 PM »
   About 4 years and I had it serviced on the loop last year by the WM mobile team. He replaced the bearings in the idler belt wheel which had died a couple days before. I am diligent about the 50 hour service and check ups too.
Offline Southside
Re: My mill is sick
« Reply #3 on: April 24, 2019, 09:38:14 PM »
It's the cam follower.  Mine did the exact same thing, I replaced all of them but only the bottom one was bad.
Offline Cutting Edge
    • Cutting Edge Saw Service, LLC
Re: My mill is sick
« Reply #4 on: April 24, 2019, 10:08:43 PM »
x2  I bet good money on the Cam Follower too.
Gonna be doing all 8 on a WM4000 in a few days that had one lock up solid, broke the shaft on (2) others - Peer brand (Made in China)
Do yourself a favor and replace with a good quality Made in USA - McGill or RCB
"Winning an argument isn't everything, as long as you are heard and understood" - W.S.
Cutting Edge Saw Service, LLC -
 - Sharpening Services
 - Portable/Custom Milling and Slabbing
 - On-Site Sawmill Maintenance/Repair Services
Factory Direct Kasco WoodMaxx Blades
Ph- (304) 878-3343
Re: My mill is sick
« Reply #5 on: April 24, 2019, 10:14:58 PM »
   Thanks guys. Did yours ever completely lock up or did they just just bind at certain points? Any gotchas or special techniques involved in replacing them?
Offline Southside
Re: My mill is sick
« Reply #6 on: April 24, 2019, 10:39:25 PM »
The bearings had failed internally, so sometimes I could push it through, other times it was all but locked up tight.  I can't recall exactly what I did but I do remember removing the rubber bumper at the end so I had a bit more run to get at least one off.  That and you will need to gather up a couple of chickens, cut their heads off, and make the voo-doo sign on the mast with the blood so your fingers can fit into those spots.
Re: My mill is sick
« Reply #7 on: April 24, 2019, 10:59:03 PM »
Southside,
   Thanks. I will try the chicken.  I already discovered that swearing doesn't work when I took the end link off the chain and removed the bearing next to the chain drive sprocket that was so tight a socket head would not fit over it and I had to remove the bracket and loosen 1/8 turn at a time with a 15/16" end wrench. After removing the bracket I realized I had not needed to remove the chain end link.
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: My mill is sick
« Reply #8 on: April 25, 2019, 04:24:13 AM »
Should roll very easily when the chain is off.  Good tip I got from a Woodmizer employee is that if the rails are lubed and a bearing is starting to go bad sometimes you can see the bearing just sliding along and not turning.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide, 2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker),  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Re: My mill is sick
« Reply #9 on: April 25, 2019, 08:39:05 AM »
TT,
    I thought so but it does not. Pushing it by hand is how we narrowed down the likely causes to either rollers or cam follower bearings or something else in the feed system. Removing the chain and drive sprocket narrows it down even more. Thanks for the input.
Offline sparks
  • Sponsor
  • Woodmizer Electrical Tech
Re: My mill is sick
« Reply #10 on: April 25, 2019, 03:42:52 PM »
Did you spin the power feed motor to make sure a magnet has not come loose and is binding the motor?
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
Re: My mill is sick
« Reply #11 on: April 25, 2019, 05:31:45 PM »
Sparks,
  Thanks for the suggestion. I did spin the shaft on the power feed motor because I too the pulley and later the entire motor off ans they spin freely. The shaft with the pulley on one end and sprocket on the other also spin freely as well as the cam follower next to the sprocket the rolls over the chain. With the entire power feed unit off the head still binds although the first thing this morning it moved freely for about 3' then bound up when I tried to pull it back so it is binding with no feed system.
  Based on the info from Southside and Cutting edge I ordered 3 cam followers today and they will be here Monday. I will replace them starting with the one on the bottom.
   Remember - the person who can smile during times of adversity has already found someone to blame his problems on. :D
Offline Southside
Re: My mill is sick
« Reply #12 on: April 25, 2019, 10:17:12 PM »
WV -
If it turns out not to be the cam follower then my account was hacked and the answer was posted by an imposter.   :D
Re: My mill is sick
« Reply #13 on: April 26, 2019, 09:26:46 AM »
   Reminds me of the old flow chart I used to see when working regular work. Started with "Was there a problem?" and went from there like:
1. Did you cause it - if yes back to front if no "No Problem."
2. Did anyone see you - if yes, back to front if no "No Problem"
3. Is there someone else you can blame - if yes no, back to front if yes no "No Problem"
4. Continues through many more steps with same loop till finally no more excuses and goes to a box that says "You're screwed"
Re: My mill is sick
« Reply #14 on: April 26, 2019, 09:54:25 AM »
1.  Did you make any money last year?
2.  How much?
3.  Send it in
Re: My mill is sick
« Reply #15 on: April 26, 2019, 10:54:41 AM »
TT,
    Did you retire from the IRS? :D
Offline gdaddy01
Re: My mill is sick
« Reply #16 on: April 26, 2019, 02:13:14 PM »
how much should we give ? the answer is more , more , more .   ccr
Offline moodnacreek
  • Sawin by the notches
Re: My mill is sick
« Reply #17 on: April 26, 2019, 06:36:32 PM »
Geeze, my sawmill was made before w.w.2 and it never done nothing like that.
Offline Bluejay27
Re: My mill is sick
« Reply #18 on: April 28, 2019, 10:54:25 PM »
We had a cam follower seize up on our 70 super a few hundred hours in, made it stop dead on its track. Turned out someone forgot to grease it from the factory. All my replacements have grease zerks and get a weekly shot. If I forget, pretty soon I'll hear it when I'm backing up.
I also had a bearing go in the power feed shaft on our '98 40 super, but I only found that because the drive sprocket was so worn that teeth were breaking off. That was about 3000 hours in though.
'98 Wood-Mizer LT40HDD42 Super, '08 LT40HDG28, '15 LT70HDD55-RW, '93 Clark GPX25 Forklift, '99 Ford F550
Re: My mill is sick
« Reply #19 on: April 29, 2019, 12:14:18 PM »
  New ones just came a few minutes ago and am fixing to go change them and lets hope that is all it was.
Wife is sick of talking about my mill.
Started by woodjunky on Sawmills and Milling
Last post March 31, 2015, 11:07:57 AM
by Warped
been sick
Started by ely on Health and Safety
Last post May 13, 2009, 12:20:20 PM
by Modat22
Sick Saw
Started by Slofr8 on Chainsaws
Last post September 25, 2003, 12:00:27 PM
by Gus
I think I am going to be sick!
Started by Kirk_Allen on Sawmills and Milling
Last post February 10, 2006, 06:00:53 PM
by Daren
