Author Topic: My mill is sick  (Read 4801 times)
Offline Bluejay27
Re: My mill is sick
« Reply #80 on: May 09, 2019, 10:08:16 PM »
The 70 super has one cam follower and bracket toward the front and a second bracket with two cam followers at the rear. The rear bracket has a pivot so both apply pressure evenly. And the cam followers are the same 1-1/2"
'98 Wood-Mizer LT40HDD42 Super, '08 LT40HDG28, '15 LT70HDD55-RW, '93 Clark GPX25 Forklift, '99 Ford F550
Online Southside
Re: My mill is sick
« Reply #81 on: May 09, 2019, 10:53:39 PM »
Top and bottom the same?
Offline Crossroads
  • letís make some sawdust
    • Kevin Bales faith family farm and portable sawmill
Re: My mill is sick
« Reply #82 on: May 12, 2019, 09:53:31 AM »
Glad you got if figured out and are back to making sawdust.
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator
Offline WV Sawmiller
    • Green's Sawmill Services
Re: My mill is sick
« Reply #83 on: May 12, 2019, 10:23:55 AM »
   I can definitely say I now know a whole lot more about the design and operational features of my mill. I also learned if you knock the set off the bottom teeth your blade wants to climb which might be a handy reminder/troubleshooting tool for others to remember.
Wife is sick of talking about my mill.
Started by woodjunky on Sawmills and Milling
Last post March 31, 2015, 11:07:57 AM
by Warped
I think I am going to be sick!
Started by Kirk_Allen on Sawmills and Milling
Last post February 10, 2006, 06:00:53 PM
by Daren
Sick Saw
Started by Slofr8 on Chainsaws
Last post September 25, 2003, 12:00:27 PM
by Gus
Sick Cat 518
Started by IMOWOOD on Forestry and Logging
Last post December 08, 2011, 04:08:30 AM
by John Woodworth
