Author Topic: Tree ID - are these white walnut / butternut logs?  (Read 1421 times)
Offline stanmillnc
    • Stanley's Sawmill - Specialty Wood Supply
« on: April 30, 2019, 04:57:31 PM »
Got a lead on huge "black walnut" logs today, so I dropped what I was doing and raced down to the site being cleared before they were chipped up. They are huge - 38" diameter at the stump and one has a nice crotch, so it was worth picking up, but looks to me like these are white walnut / butternut. These two are the same species, right? Bark on these seems a less deeply furrowed and more gray than brown than I've seen on black walnut. Also, seems like less dark heartwood and more sapwood than I normally see with black walnut. Can someone please confirm? Thanks!
Offline Don P
    • Calculator Index
Re: Tree ID - are these white walnut / butternut logs?
« Reply #1 on: April 30, 2019, 05:30:42 PM »
Quite likely, this was one we got a week or so ago, nice score!
A butternut crotch end table from a year or two ago.
Offline KEC
« Reply #2 on: April 30, 2019, 09:55:59 PM »
I don't know what they are, but I don't believe it's Butternut. Butternut has gray bark and the ends of the logs don't look right.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #3 on: April 30, 2019, 10:07:00 PM »
I believe that it is hickory.  Many people confuse hickory nuts with walnuts.
Offline stanmillnc
« Reply #4 on: April 30, 2019, 10:26:45 PM »
Not hickory for sure. Ive cut and milled all types of hickory and this isnt nearly as hard and looks very different. It is not dense like black walnut either.....no nuts lying around unfortunately.
Offline Don P
    • Calculator Index
« Reply #5 on: May 01, 2019, 06:34:25 AM »
It is a good bit less dense than black. I pick up the same walnut smells while milling it, not as strong but still walnut.
Offline WDH
« Reply #6 on: May 01, 2019, 07:49:20 AM »
OK.  Next option is elm.  Looking closely at the end grain, are the latewood pores arranged in wavy bands?
Offline Don P
    • Calculator Index
« Reply #7 on: May 08, 2019, 08:53:22 PM »
We were sawing today and something else hit me in the face :D
The inner bark of a butternut is a pretty bright yellow. It's also slipping now.  The bark was used during the civil war to dye the uniforms of some southern troops a brown-yellow which is where the term "butternuts" came from.
Edit: From this USFPL link, if you use iron as a mordant with butternut bark dye you get a grey uniform, that makes more sense.
https://www.fs.fed.us/wildflowers/ethnobotany/dyes.shtml
Offline stanmillnc
« Reply #8 on: May 09, 2019, 07:29:13 AM »
Here she is opened up - looks like butternut to me!
Offline Don P
    • Calculator Index
« Reply #9 on: May 09, 2019, 08:03:23 AM »
The color is right, more sapwood than I'm used to but every tree is an individual. Butternut is very often a cross between Japanese heartnut, of which there are several, and our butternut, the cross is a buart. Our natives are in decline from an Asian canker fungi that the crosses are often able to survive. It's apparently kind of new to the dendro guys and gives them fits trying to save pure strains, the two freely interbreed.  I always have trouble on a screen vs being there. Another clue, the pith is just like a black walnut, that loose open pith. I messed up on one set of cuts yesterday and made a group of quartersawnish cuts, butternut is much more handsome in flatsawn orientation.
After that recollection on it being a dye yesterday I was googling last night and confirmed that is was a confederate dyestuff, shot off an email this morning to the lady that runs the local living history museum, makes period clothing and is part of a reenactors group. She has made and used the dye and is coming after some bark.
Offline moodnacreek
  • Sawin by the notches
« Reply #10 on: May 09, 2019, 01:00:47 PM »
So there is and was butter nut down south. That is not what I would have expected. It has become rare here in s. n.y. and I have only sawn a few in 35 years but up north near the border you can find big ones where they have no black walnut. It is much colder up there with shorter summers.
Online Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #11 on: May 09, 2019, 08:51:07 PM »
 There is at least one in Mississippi.  I planted about 30 and this is the lone survivor.  Several others came up but died shortly there after.  @Dodgy Loner sent me the nuts.  This one is several years older now, probably 16 foot tall or so.  Hope it makes it.  Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline WDH
« Reply #12 on: May 09, 2019, 09:57:41 PM »
I am not convinced that it is not hickory. That is exactly what hickory is supposed to look like.
Offline moodnacreek
« Reply #13 on: May 10, 2019, 08:15:00 AM »
WDH, yes but butternut is really soft.
Offline stanmillnc
« Reply #14 on: May 10, 2019, 08:18:01 AM »
Yes, this wood is soft; certainly not hickory - I've cut a lot of hickory and its very hard, not comparable whatsoever with this wood. I agree that the grain pattern is similar to some hickory however.
Offline Hewer of Wood
« Reply #15 on: May 10, 2019, 08:18:15 PM »
Well if its not hickory then maybe a type of elm? Or possibly a soft maple? Pretty sure its not Butternut though.
1997 Timber Harvester 1967 Pettibone Super 8 and too much sawdust. Joshua 9:21
Offline KEC
« Reply #16 on: May 10, 2019, 08:42:07 PM »
I am puzzeled enough by this that I'll try to go behind the house and get a photo of a butternut and put it on here. I don't see butternut  here.
Offline KEC
« Reply #17 on: May 11, 2019, 06:48:47 PM »
A Butternut Tree in Southern Onondaga County, N.Y.
Offline moodnacreek
« Reply #18 on: May 11, 2019, 09:39:24 PM »
That's butternut, related to b. walnut which is related to hickory.
Offline Don P
    • Calculator Index
« Reply #19 on: May 11, 2019, 10:29:07 PM »
Tree service guy wants serious money for walnut logs!
Started by Small Slick on Sawmills and Milling
Last post March 18, 2014, 10:27:26 AM
by 5quarter
Nice load of white oak logs from local tree service
Started by Kelvin on Sawmills and Milling
Last post August 29, 2008, 07:51:34 AM
by Ironwood
Amazing butternut on walnut graft wood
Started by low_48 on General Woodworking
Last post January 18, 2015, 01:58:39 PM
by tule peak timber
Serious insect pest affecting nut production in butternut/walnut
Started by SwampDonkey on Forest Education
Last post August 14, 2014, 02:32:37 PM
by SwampDonkey
