Author Topic: Lt10 drive belt tension setting  (Read 407 times)
Offline SeanG
« on: May 01, 2019, 10:28:58 PM »
Hello everyone I was looking for the drive belt setting for my woodmizer lt10 I changed the motor from a 7hp Kohler to a 13hp predator motor and was wondering if that would affect what the setting may be for it, if not then I would be looking for what the setting is.
Thanks for your time guys and gals
Sean
Offline Chuck White
  • Sawing Mobile since 2005
Re: Lt10 drive belt tension setting
« Reply #1 on: May 02, 2019, 06:43:13 AM »
Welcome to the Forestry Forum, SeanG!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline SeanG
« Reply #2 on: May 02, 2019, 06:32:29 PM »
Hello Chuck
Offline Chuck White
« Reply #3 on: May 02, 2019, 06:51:30 PM »
Sean, might want to go to the front page and scroll all the way to the bottom and talk to the Wood-Mizer folks!
~Chuck~
Offline bigtim
« Reply #4 on: May 02, 2019, 11:20:05 PM »
Hello Sean,the manual says 19/64 with 6 lbs pull for a new belt 4 lbs for a used belt.Hope this helps,mine is a 2010.
Offline SeanG
« Reply #5 on: May 03, 2019, 09:47:39 AM »
Thanks bigtim
Woodmizer LT10 belt tension with new 10hp motor
Started by ntkonn on Sawmills and Milling
Last post November 23, 2014, 08:43:22 PM
by ntkonn
Drive belt tension
Started by Grower on Sawmills and Milling
Last post July 12, 2008, 09:16:42 PM
by Grower
Drive belt tension tester
Started by SAnVA on Sawmills and Milling
Last post April 07, 2013, 07:33:04 PM
by MartyParsons
question
WM LT40 Drive Belt Tension
Started by DR_Buck on Sawmills and Milling
Last post February 01, 2005, 07:55:28 AM
by Bibbyman
