Author Topic: What style is this? Where to look for stock building plans?  (Read 1062 times)
Offline Brad_bb
What style of house is this?  I'd like to find a set of stock plans for one like this so I can do a cost workup.  Where should I start looking for stock plans?  I'm doing this for a friend of mine.
Offline twar
  • Displaced southerner
Re: What style is this? Where to look for stock building plans?
« Reply #1 on: May 06, 2019, 02:35:22 AM »
In my amateur opinion, I think this is a Cape Cod-style house. It certainly has Cape Cod elements.
Offline 47sawdust
« Reply #2 on: May 06, 2019, 06:11:14 AM »
A good lumberyard will have a design/estimating team that should have plans for a home similar to the one pictured.They should also be able to do a materials take off for you.
Also do a search for New England style homes or Capes.The one pictured looks very similar to homes here with a partial or full screened porch on the back.
Mick
Online thecfarm
« Reply #3 on: May 06, 2019, 06:20:30 AM »
I also would have a door with the small side windows on each side of the door that goes the full length.
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #4 on: May 06, 2019, 07:47:08 AM »
My opinion it is more Ranch style than Cape Cod. Especially with that split pitch roof, and wrap around porch. A quick interweb search I found "houseplansandmore" had some similar houses pictured.
Offline curved-wood
« Reply #5 on: May 06, 2019, 07:59:54 AM »
Should not be difficult to find some plans. Here is a company that sells plans : https://www.drummondhouseplans.com/
You could have a bit of an ides for the inside partitions and a rough estimate on $$. It may be enough to have a more precise price from your lumber yard
Offline ljohnsaw
« Reply #6 on: May 06, 2019, 09:29:41 AM »
When I lived back east, all the "Cape Cod" style houses had neither a split pitch roof or eaves.  The rain gutters were right at the wall with no overhang at the ends, too.  Looks more "Farmhouse" to me with the porches.
John Sawicky
Offline Brad_bb
« Reply #7 on: May 06, 2019, 10:30:32 AM »
This is not easy.  Going through those two web sites and not seeing it.
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #8 on: May 06, 2019, 10:54:23 AM »
Could be a custom job.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #9 on: May 06, 2019, 12:07:18 PM »
Ranch, or raised ranch, not sure of the difference. Not a Cape.
Offline RichTired
« Reply #10 on: May 06, 2019, 02:18:40 PM »
Tully Burch Home Design Center Birmingham, Al plan no. 869.
I built a modified version of this plan with basement back in 1996.
Wood-Mizer LT15GO, Kubota L2800, Husqvarna 268 chainsaw, Logrite cant hook, Ford F-150 Fx4
Richard
Offline olcowhand
  • I'm new- ish!
« Reply #11 on: May 07, 2019, 04:27:15 AM »
Brad,
I definitely would classify it as a Cape Cod Style (check Google, it has many of the design elements that define the style). I built one for my MIL back in '01 that is the same basic design. The Dormers can be added pretty much any way you like; I put a low- pitch shed roof dormer in the back of hers on the second story to put a full bath in.
I may have a set of plans around somewhere; let me check, and I'll IM you for an address to ship them to if have them. (It may take me until Saturday...)
Steve
They say the mind is the first to go; I'm glad it's something I don't use!
Ezekiel 36:26-27
Offline florida
« Reply #12 on: May 08, 2019, 04:17:52 PM »
Brad,
That's called Cottage style.
General contractor and carpenter for 50 years.
Offline Brad_bb
« Reply #13 on: May 10, 2019, 03:09:02 AM »
Still haven't found a plan for a similar house.  Tully Birch that RichTired noted doesn't seem to have an  online presence/website.  So it must be on paper file with them.
Offline florida
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #15 on: May 10, 2019, 03:09:54 PM »
You might have better luck searching for story and a half house plans.
Home designs have incorporated so many elements from various architectural styles it is hard to call a modern house a specific architectural style anymore.
Cottage, Cape Cod, Low Country and Farmhouse all come to mind when I look at the photo.
The photos above are my variation of the story and a half farmhouse/cape cod. I built it 29 years ago.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline WLC
« Reply #16 on: May 10, 2019, 08:12:00 PM »
Try houseplans.com  I found the one I linked below in just a few minutes.  Not quite an exact match, but close.  Narrow down the search parameters and you'll find something close.
Not to be a smart alleck, but if the pic you posted is of an actual house nearby and not an internet photo why not just ask the owner?  Most folks will tell you where they got the plans or what builder built the house and you could contact them.
https://www.houseplans.com/plan/1778-square-feet-3-bedroom-2-50-bathroom-0-garage-country-farmhouse-sp154437
Woodmizer LT28
Branson 4wd tractor
Stihl chainsaws
Elbow grease.
Building a Texas Style BBQ
Started by Qweaver on General Board
Last post July 31, 2015, 02:11:27 PM
by sandhills
Building a old style circle mill
Started by Jesper Jepsen on Sawmills and Milling
Last post October 27, 2016, 07:50:43 PM
by bandmiller2
Blockbau, a log building style (well, sort of)
Started by D L Bahler on Timber Framing/Log construction
Last post April 10, 2012, 11:20:34 AM
by nsmike
Building Plans
Started by craigc on Timber Framing/Log construction
Last post December 02, 2012, 10:03:32 AM
by Jim_Rogers
