Author Topic: Rebuilding an old carb off a Briggs & Stratton engine...  (Read 676 times)
Offline ljohnsaw
« on: May 06, 2019, 11:02:54 PM »
I posted this winch elsewhere:
Its got an old Briggs & Stratton engine - 12-14hp?  The carb was leaking from the main jet adjusting screw on the bottom side of the bowl so I figured I pull the carb and clean it up.  To pull the carb apart, you need to pull a brass tube that goes diagonal from the main jet needle up to the top of the carb.  Only problem is the brass threads have pretty much fused with the pot metal of the bowl.
I was able to finagle the carb apart and found the next problem.  The brass pin that holds the float in place is also fused.  I have to get that off to change the gasket.  I put it back together (a few times now) and now it seems the float valve is not sealing up - gas leaking out.  I tested by blowing in gas line fitting and it works fine that way.  I had some spare valve needle thingys but still leaks gas.  I did clean it up with carb cleaner so there shouldn't be gunk on the valve seat.  Maybe the gunk was what helped it seal... ::)
Anyhow, I would like to track down a carb kit or make new gaskets but I have to get it apart correctly.  Any choice ways to get it apart without damage?
John Sawicky
Offline Steve Crook
Re: Rebuilding an old carb off a Briggs & Stratton engine...
« Reply #1 on: May 07, 2019, 12:01:47 AM »
I ran in to one of those carbs years ago. the brass tube that goes through the carb broke and I had to drill it out. the remainder of the tube had to be removed with a tap. I Had to make a special tap because it is a goofy thread pattern. Like 3/8 34 or something like that.I believe that the replacement tube was available from briggs.
If that is what you have leave a message to me and you can have the tap. i think I may remember where it is. if not it is no big deal to make another.
Offline Old Greenhorn
« Reply #2 on: May 07, 2019, 06:04:02 AM »
I have had a few of these over the years, always a pain when they start to corrode. On more than one occasion I have found pin holes in the float causing it to sink and keep the needle valve open. Tough to notice if you are not looking for it. I always have trouble making these run clean and neat. The gaskets always seem to leak from someplace.
 Good luck.
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) I mill for fun and my mental health. NYLT Certified.
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #3 on: May 07, 2019, 08:55:18 AM »
Might be time for a Chonda ??? :)
Offline luap
  • Not as good as I once was
« Reply #4 on: May 07, 2019, 09:37:34 AM »
You have a couple of options. This carburetor comes in two sizes with the relative same shape. Your best option is to replace the carb. I Save Tractors sells them, and they are available on Amazon. Jacks small engines have rebuild kits. You could also install a gas line shut off valve and just remember to turn on-off as needed. besides the needle seat, the other problem with these carbs is the wear on the throttle shaft leaks air affecting the fuel air ratio. They sell new bushings for the throttle shaft but the throttle shaft is usually worn also. These few items alone almost equal the price of an amazon carb.
Offline sawguy21
« Reply #5 on: May 07, 2019, 11:48:24 AM »
Those carbs tend to leak where the brass nozzle seats against the upper carb body. Sometimes it can be cured by grinding the threads off the old nozzle and dabbing valve lapping compund on the taper, work the nozzle back and forth with a screwdriver. In your case I would replace the carburetor with an aftermarket, the price of a new OEM will scare you.
Offline ljohnsaw
« Reply #6 on: May 07, 2019, 02:59:41 PM »
Yeah, I'm thinking a replacement carb.  It was running good until I messed around with it - the engine is fine.  Now the problem.  The carb has no numbers on it and the engine has multiple layers of black and yellow paint obscuring everything but an embossed B & S.  I can make out the faint outline of the B&S sticker on the top of the shroud.  So I've got nothing to do a look up.  :-\
On the plus side, the outside of the carb is really clean...  On the other side of the engine is the gas tank (about 1 gallon) and it has a glass bowl water separator with a shutoff valve.  This is an updraft carb, but has a side intake.  What would you call it?  Steve Crook, did yours look like this?  Did you have a carb number?
John Sawicky
Offline Steve Crook
« Reply #7 on: May 07, 2019, 04:04:36 PM »
     I  do not recall having #s on mine but it is a two-piece flo-jet carb.
You do need to remove what the book calls the nozzle to separate the two halves. that is the angled brass tube.running up through the carb.
It was mentioned about the throttle shaft having excess play. that was a problem on mine. it required making bushings drilling and installing.
Offline ljohnsaw
« Reply #8 on: May 07, 2019, 04:30:58 PM »
Problem is I can NOT get the cross tube out.  It is corroded in place for all eternity.  I got a hit on another forum (garden tractors) to use ISaveTractors.com and a medium or large Flojet carb.  Turns out mine is the medium one.  Since this engine is circa 1972, I figure it could use a new carb so I just ordered one.  They also had a 10% off your first order so shipping was basically free.  Now I know I shouldn't have any problems with this when I use it this summer.
John Sawicky
Offline hamish
« Reply #9 on: May 07, 2019, 04:55:12 PM »
Heat is your friend, the brass and the composition of the body with expand and contract at different rates.  A simple heat gun with allow you take it apart easily.
You can buy an aftermarket updraft carb for most likely less than $30 USD.
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
Offline luap
« Reply #10 on: May 08, 2019, 04:29:50 PM »
Every post war Briggs engine I have seen has three series of numbers-Model, type and code stamped in the sheet metal fly wheel housing, typically filled  in with paint. With the series number you can just find it on Jacks small engines or small engines parts  warehouse.
Briggs & Stratton
Started by JBS 181 on Sawmills and Milling
Last post December 18, 2010, 07:42:19 PM
by Slabs
Briggs and Stratton won't run
Started by Tom on General Board
Last post November 26, 2007, 07:17:04 PM
by Polly
Help with 8 h.p. Briggs & stratton ?
Started by bama20a on General Board
Last post April 27, 2011, 01:05:37 PM
by red oaks lumber
35 HP Briggs & Stratton Vanguard
Started by woodbowl on Sawmills and Milling
Last post June 21, 2006, 01:24:35 PM
by tcsmpsi
