Author Topic: White birch for framing lumber?  (Read 418 times)
Offline Haleiwa
  • Clinton county, New York
« on: May 07, 2019, 11:27:14 AM »
Walking a site that I plan to start cutting this summer.   Mostly junk/firewood and fence posts, plus a little storm damaged pine.   There is some white birch up to about 12 inches diameter maybe 30 feet tall and straight as you could ask for.  Would it work to say 4 by 6 posts for a shop?  It would rest on a  stem wall and be completely closed in, so no ground contact or weather exposure.  Strength ratings are about 90 percent of Douglas fir.  Will it hold fasteners?  Stay straight?  I  don't mind sawing small stuff,  and firewood is really the only other option for it.
Socialism is people pretending to work while the government pretends to pay them.  Mike Huckabee
Offline luap
  • Not as good as I once was
Re: White birch for framing lumber?
« Reply #1 on: May 07, 2019, 01:41:16 PM »
  Properly stacked and stickered  it will stay straight. You may have to predrill holes for fasteners. The sap wood is less dense and won't require predrilling. It holds fasteners well. I like working with birch and it has many positive qualities. In the hand weaving world, it is a favorite for building looms.
Offline moodnacreek
  • Sawin by the notches
« Reply #2 on: May 07, 2019, 06:11:18 PM »
35 years ago I would frame shops and sheds with any wood I could dog on the carriage. Back then we had dry summers most years. I think it's been 23 years since a real dry summer and any thing I built with white hardwoods is full of powder post beetles now.
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #3 on: May 08, 2019, 12:10:03 PM »
You may want to see if your trees are good enough to cut logs to sell for veneer grade. White Birch is used a lot for making plywood, and may be worth more than cutting framing lumber from it. Also there is a market for small sticks to sell for home decor. If you do cut it for firewood, be sure to split it. The bark is water tight, (why they made canoes from the bark), and will otherwise rot from the inside out.
White birch for framing???
Started by WLC on Sawmills and Milling
Last post January 04, 2016, 01:24:12 AM
by starmac
Neophyte Opinion: White Oak Better Than Red Oak For Framing Lumber
Started by plaindriver on Sawmills and Milling
Last post August 13, 2013, 09:16:40 PM
by WDH
white birch
Started by coxy on Drying and Processing
Last post April 15, 2014, 06:42:46 AM
by coxy
White birch question
Started by Kevin on Ask The Forester
Last post April 14, 2008, 10:28:12 PM
by Kevin
