Author Topic: Rear hydraulics for a farmpro?  (Read 234 times)
Offline Compensation
« on: May 08, 2019, 04:17:26 AM »
So I went to the dark side and got a farmpro 2425 to help with loading sawdust and other minor things. It has a FEL and I want to use a backhoe and possibly a stump grinder on the rear. Trying to figure out how to go about it since it doesnt have the hyd hookups in the rear. Thought about using a couple of T's up front or running from the FEL. Then I seen some have a plate to bolt up a pump above the pto. Figured I would ask before I start spending money on it.
D4D caterpillar, lt10 Woodmizer, 8x12 solar kiln, enough Stihl's to make my garages smell like their factory :) Ohh and built Ford tough baby!
Offline snowstorm
Re: Rear hydraulics for a farmpro?
« Reply #1 on: May 08, 2019, 06:35:32 AM »
you can use a diverter valve to run the hoe off the pump for the fel.
« Reply #2 on: May 08, 2019, 07:58:51 AM »
Like the power beyond port and t into the return?
Offline snowstorm
« Reply #3 on: May 08, 2019, 03:43:33 PM »
if it has a power beyond valve section you can use that
Rear End Loader
Started by Firebass on Sawmills and Milling
Last post May 03, 2009, 06:17:27 PM
by okie
Backhoe on the rear of a F-550
Started by Ironwood on General Board
Last post November 20, 2008, 11:12:43 AM
by Ironwood
TJ 350 rear ratio?
Started by BOBWOOD on Forestry and Logging
Last post May 07, 2011, 08:40:37 PM
by BOBWOOD
540b rear end
Started by br389 on Forestry and Logging
Last post September 17, 2013, 07:24:14 AM
by br389
