Author Topic: Looking for mobile sawmill near Bettendorf, Iowa  (Read 323 times)
Offline wesdor
« on: May 08, 2019, 12:46:15 PM »
I have checked Wood-Mizer for the past 2 days and continue to receive an error when looking for sawyers in Iowa.
A friend called me yesterday looking for a mobile sawmill. He has a few rather large walnut trees that he wants to have sawn. He has no delusions that these are high dollar trees, only wants to have lumber from trees that were taken down in preparation for building a house.
Anyone here provide this service in the Eastern Iowa, Western Illinois area?
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
Re: Looking for mobile sawmill near Bettendorf, Iowa
« Reply #1 on: May 08, 2019, 01:32:03 PM »
The Forestry Forum has a search function for sawmills, as does Sawmill Finder, Sawmill Trader, Wood Web, and most state forestry departments maintain a directory of sawmills.
07 Timberking B-20, Custom-made log arch, 20' trailer w/ log loading arch, F350 SD flatbed dump.  Princeton piggy-back forklift.  Bobcat S250, Stihl 025C 16" and a Husqvarna 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says "He's sawin logs", I ain't snorin'.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #2 on: May 08, 2019, 09:27:56 PM »
   Maybe there are no WM Pro-Sawyers registered in Iowa. I get the same message when I try but when I select WV I get a list of us. Do check here on the FF in the Find a Database. Good luck.
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #3 on: May 08, 2019, 09:31:25 PM »
Craigslist and FB Marketplace are also ways to find mobile sawmills and sawyers.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline wesdor
« Reply #4 on: May 08, 2019, 10:53:01 PM »
Thanks for the advice. Nothing found in the Find Data base in Iowa. (I didnt know this existed- thanks Tom).
I did find a name for them in Geneseo, Illinois which is not far. I passed the info on and will see what happens.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #5 on: May 09, 2019, 07:36:08 AM »
Woodmizer will give phone numbers of sawyers within a radius of the zip code you provide. These are persons who have agreed to be on this list, not just owners.  If you need more names ask for a wider radius.  Need to call in  and select the number for ".....locate a sawyer".
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker),  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline stihltoomany
  • I'm new, but not real new!
« Reply #6 on: May 09, 2019, 09:22:32 AM »
I am within 50 miles of Bettendorf Iowa I have an LT40 super hydraulic wood mizer I don't know what you call large logs but once they get over about 30" they get to be time consuming give me A PM and we'll get together
Way too many saws, mostly STIHL
 Bobcat S650, Bobcat 331 excavator
and other dirt toys
Looking for hyd bandsaw mill, Timberking used maybe? NOT anymore!
 WoodMizer LT40 super
Offline wesdor
« Reply #7 on: May 09, 2019, 11:36:34 PM »
stihltoomany - sent you a PM
Iowa DNR Sawmill - Yellow River State Forest
Started by inspectorwoody on Sawmills and Milling
Last post October 21, 2007, 10:11:22 PM
by inspectorwoody
First Mobile Sawmill Job in Forever...
Started by DR_Buck on Sawmills and Milling
Last post October 31, 2018, 09:07:01 PM
by DR_Buck
Mobile Dimensions Sawmill??????
Started by lawnsbylane on Sawmills and Milling
Last post January 13, 2016, 11:48:29 AM
by 4x4American
mobile dimensions sawmill
Started by cwk266 on Wanted
Last post May 04, 2008, 08:32:07 PM
by cwk266
