Author Topic: First Carbide Blade on the LT40  (Read 928 times)
Offline richhiway
  • Rich
« on: May 08, 2019, 08:43:13 PM »
Going to see how long it lasts. Cut about 400 b.f. so far.
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Offline Peter Drouin
    • A&P Saw mill LLC
Re: First Carbide Blade on the LT40
« Reply #1 on: May 08, 2019, 09:31:36 PM »
I just got my diamond cbn to sharpen the carbide blades I have.
I think I will not run them too long, Just a day or two. so I won't have to take too much off to get it sharp.
I did a bunch of reg 7.  some I use this past winter. Some I had to go around 2/3 times to get them sharp.
The carbide blades cut frozen Hemlock real well.
I ordered more carbide blades.
A&P saw Mill LLC.
License NH softwood grader.
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #2 on: May 09, 2019, 09:00:16 AM »
I was having problems with 10's they gave me with the new LT40. Wavey wood, just a mess, spent time trying to adjust the new mill, I was sawing semi frozen pine, WM sent me a 7carbide. What a difference,  I ran that blade for over 2000 bd ft of the pine, I ordered more 7 carbides and also 7 turbo's. There is just no comparison to the 7's carbide or turbo's.
The 10's are just hanging in the shop, I might use them for logs I think have hardware in them.
I believe that we all will end up with the 7's, even the guys with the smaller horsepower mills.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #3 on: May 09, 2019, 09:07:04 AM »
Just regrind the 10ís to 7ís.  I never had any luck with 10ís either.  All I use are standard 7ís but have a couple carbides to try.
HobbyHardwoodAlabama.com
Offline bandmiller2
« Reply #4 on: May 09, 2019, 07:56:36 PM »
My bandsaw sharpener is set at 7 degrees and that's where it stays. Next band order I may try 4's. Frank C.
Offline Stephen1
    • muskoka Sawmill
« Reply #5 on: May 09, 2019, 09:37:38 PM »
YH I'm not against regrinding to 10-7 does it seem to bother the CBN wheel at all? How many times around does it take to reshape?
Offline richhiway
  • Rich
« Reply #6 on: May 09, 2019, 10:14:28 PM »
I just sawed up some Cherry and Maple and used a 4 degree blade. worked fine.
Woodmizer LT 40
Stihl Chainsaws
« Reply #7 on: May 09, 2019, 10:44:36 PM »
With my BMS 250, it takes three grinds to make a complete new profile to go from 10 to 7.  The first cut grazes the full face and puts the new angle on it and gets 3/4 of the gullet except the back top of the tooth tip.  The second cut goes a little deeper and gets the full profile but is a pretty aggressive drop.  The third cut is a light confirmation cut to make sure the whole profile is fully developed.  My BMS 250 will do a pass in 2.5 minutes, so 7.5 minutes per band to re-profile.
I've seen no damage to the CBM, the key is to grind moderately when reshaping.
Offline Dana Stanley
  • For fun and profit!
    • Yankee Wood Signs
« Reply #8 on: May 10, 2019, 07:29:23 AM »
I have 14HP I would like to try a 7 but every thing I have read says 10 is best for lower HP. I want to get a CBN wheel so I will need to investigate that before I get it. I have 1o 10* bands now!
Making Sawdust, boards and signs.
Woodland Mills HM-126
Kabota B-7800 with backhoe and loader
Ford Ranger, Husqvarna 455 20", Mac 610 24", other chainsaws 14"
Matthew 3:10
« Reply #9 on: May 10, 2019, 07:39:34 AM »
I had an LT15 with a 15 hp engine and my favorite bands were standard 7's, .045".  They worked well.
I used the same bands on my LT40, and are now using the same angle on my LT70.
Offline Mossy Chariot
  • Forest Vue LLC
« Reply #10 on: May 10, 2019, 07:52:16 AM »
Iíve only run 4ís on my LT35 which was suggested by WM when I bought the mill. I saw mostly oak and hickory. I plan to try some 7ís. What differences can I expect?
Tony B
LT35HD, Kubota 3450, Wallenstein Skidding Winch, Stihl 250 & 460, can-am Defender
Online btulloh
« Reply #11 on: May 10, 2019, 07:53:56 AM »
That's what I went through.  I'm not sure why that seems to be the gospel.  Everybody on here with low power that tried 7's has found them to work better.  When I switched to 7 degree Kasko's, it was a big improvement and I'm at 9.5 hp.
Offline bandmiller2
« Reply #12 on: May 10, 2019, 07:50:50 PM »
I may be wrong on this but I believe originally most bands were 10 degree to help the feed on manual push mills. Hold a chisel at 10 degrees and it tends to dig in at 4 degrees it acts like a scraper. Frank C.
Offline Percy
  • Resident trouble maker
« Reply #13 on: May 10, 2019, 11:16:28 PM »
You may have something there......I use 13 degree blades and cut mainly softwood with them Feed rates are fast.....and... they let you know  when they are dull with out a doubt...
carbide saw blade
Started by duke401 on Sawmills and Milling
Last post September 13, 2003, 03:52:45 PM
by woodhaven
Carbide Chainsaw Blade
Started by Victor on Chainsaws
Last post December 14, 2016, 06:32:00 PM
by David-L
Carbide or regular teeth in a new blade
Started by Sawyerfortyish on Sawmills and Milling
Last post March 06, 2010, 02:09:36 AM
by Sawyerfortyish
WM LT40 uses a 13'2" blade?
Started by golddredger on Sawmills and Milling
Last post March 08, 2014, 07:27:53 PM
by Brucer
