Author Topic: Treating planter box?  (Read 1138 times)
Offline terrifictimbersllc
    • Terrific Timbers LLC
« on: May 10, 2019, 08:44:30 AM »
Got a call a few minutes ago about what might be best to treat planter boxes to make them last longer.
For flowers.  She wondered if diesel/oil was good.
Wondering about that and whether maybe just 6 mil plastic.  Photo below.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide, 2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker),  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Online btulloh
Re: Treating planter box?
« Reply #1 on: May 10, 2019, 08:55:08 AM »
Diesel / oil doesn't go well with plants.  It does make a very effective killer though.
6 mil Plastic sounds good or she may be able to find plastic trays that will fit.
I'll be curious to see if anyone knows of an effective surface treatment.
HM126
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: May 10, 2019, 09:17:40 AM »
Or calk/seal all of the cracks and give it a good solid coating of roofing sealer.  I would want a ~" buildup to insure that no moisture reaches the wood.  There would also have to be drain holes in the bottom.
Offline caveman
  • In the land of the blind the one eyed man is king
« Reply #3 on: May 10, 2019, 12:52:05 PM »
I made one several years ago out of live oak and lined it with tar paper.  the bark has begun to slip but it is still solid.  Had I used a more rot prone wood I am sure it would not have held up as well.
Caveman
Offline bluthum
  • Tick magnet.
« Reply #4 on: May 10, 2019, 01:13:22 PM »
copper napthenate, maybe 10% is considered fairly safe around growing plants.
Offline Bruno of NH
« Reply #5 on: May 10, 2019, 05:20:30 PM »
You could also line it with ice and water shield self sticking membrane
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,Mahindra 3540 cab tractor loader F350 4x4 dump and lot of contracting tools
« Reply #6 on: May 10, 2019, 06:31:49 PM »
Thanks for all the ideas. You're making me look good!   :)  Sent her the link for her to watch.
Funny thing, she said she has been a roofer, and will send pix back of what she comes up with.
Offline tule peak timber
  • roborob
    • tule peak timber
« Reply #7 on: May 11, 2019, 06:58:11 AM »
I've always been uncomfortable putting water inside of wood (unless it is a wine barrel LOL). Planters need well planned drainage, possibly with a bit of rubble in the bottom so roots don't sit in stale water.Liquid , paint-able, polyurethane sealant is a good choice. Vulkem, Liquid Flex-Seal,L&R liquid rubber, Progard EPDM, all pretty good options to coat the inside of planter boxes.
    Some nice looking planters on this thread that show a potential of extra $$ from slabs and skins..........
Offline curved-wood
« Reply #8 on: May 11, 2019, 07:57:16 AM »
Surfacing burning : Shou sugi ban ...it is the name for surfacing burning for increasing root resistance. Easy to find info on YouTube. We did some flower boxes using that technique so far so good...time will tell.  In the past I did flower boxes with live edge untreated of any sort. Nice look but not lasting. Live edge has the sap wood which is not very root resistant even with cedar.    I try to stay away as much as possible from chemicals...I have to do my environment share somewhere.
Online btulloh
« Reply #9 on: May 11, 2019, 08:19:58 AM »
Some good ideas here.  I like Bruno's water shield suggestion.
HM126
Offline Sawmill Man
« Reply #10 on: May 11, 2019, 08:30:36 AM »
How would anchorseal work as a moisture barrier if used just on the inside?
"I could have sworn I went over that one with the metal detector".
Offline OffGrid973
  • Off Grid
« Reply #11 on: May 16, 2019, 10:12:20 PM »
Black pond liner with a drain plug cut out in the bottom...make sure the water can feed to this drain area (may need few).   Spar varnish on the outside edges keeps it looking nice, but dont put it inside the planter...good luck.
https://www.lumberjocks.com/topics/7741
Your Fellow Woodworker,
- Off Grid
Offline low_48
« Reply #12 on: May 17, 2019, 12:17:00 AM »
Why spend so much time protecting the interior when the outside will be hit with an occasional rain shower, but water from a hose every day? Use it till it rots and then make another one. Window boxes are hell on house paint and siding. The person uses a big shower head on the hose and the siding gets wet everyday.
Offline doc henderson
« Reply #13 on: May 17, 2019, 12:58:56 AM »
made a planter for my wife out of a old spring mech. rocking chair.  took off the springs, mad a box out of locust wood, prob. honey, and lined the inside with fiberglass mat and resin.  she did stencils on the arms and back.  about to put it in the burn pile.  the box is perfect, but outside on the legs and back, every thing is de-laminating.  I will try to get a pic, but is like an inside out boat.
timberking B 2000, 277c track loader, PJ 32 foot gooseneck, 1976 F700 state dump truck, JD 850 tractor.
« Reply #14 on: May 17, 2019, 05:02:51 PM »
here are pics of our planter after 4 years of service.  the box is still good, but the old rocker is done.
stencils from hobby lobby, good hubby wifey project. lined with fiberglass cloth and resin from WM auto section.  good as new.  full of dirt water and plants for years.  drain holes in back and bottom.
Offline low_48
« Reply #15 on: May 17, 2019, 09:12:57 PM »
That could have been a chamber pot Doc! LOL
Except for those drain holes!
log planter
Started by Dave H. on General Woodworking
Last post June 25, 2016, 07:54:08 AM
by lowpolyjoe
Planter Plates
Started by farmerdoug on For Sale
Last post January 30, 2010, 09:22:28 AM
by farmerdoug
cedar planter
Started by hackberry jake on General Woodworking
Last post April 15, 2014, 08:41:35 PM
by WDH
2-4 Row Mechanical Planter
Started by Kirk_Allen on Wanted
Last post December 22, 2005, 07:16:25 PM
by Frank_Pender
