Author Topic: Toe Boards - types, methods, substitutes  (Read 797 times)
Offline John Bartley
  • Location: 13 Critchley Avenue, PO Box 36, Monteith Ont, P0K1P0
« on: May 13, 2019, 08:11:59 AM »
There was a thread recently about "how do we level logs to get to a cant"?   I responded with a photo of my toe boards and several other stopped by with comments about ways and means to accomplish the levelling.
I'd like this thread to be a photographic thread (mostly) with images of toe boards or other ways to accomplish the same.   If taking pictures or posting them just ain't your thing, then please describe to your hearts content, but like they say .... "a picture is .... etc".
Here's my toe boards :
- basically a frame that sits in the saw mill frame
- has a small hydraulic jack to operate a:
- scissor type lift with a:
- HDP top on it for easy sliding and log rolling
These are factory built to fit my mill, so credit for the design to SMG (Gilbert SawMills)
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
Offline RAYAR
  • Retired May 2/19 more time to play with my mill
Re: Toe Boards - types, methods, substitutes
« Reply #1 on: May 17, 2019, 01:16:12 PM »
Mine are simple and quick to use. They are a scissor jack with a piece of rod bent and welded for a crank handle. There is currently a piece of flat bar welded to the top for log support (not my build). No loose parts to lose or keep track of. There is one mounted (welded) near each end of the bed. So far, they've worked good for me.
(edit: they are bolted down, not welded)
Added two recent photos of toe-boards:
Front
Rear
mobile manual mill (local build) (mods & additions on-going)
Shop built auto band sharpener
Husqvarna 50, 61, 254XP
96 Polaris Sportsman 500
2006 Ranger 4X2 w/cap, manual trans
Offline Wudman
  • Eat, drink, and be merry before you go on quota!
« Reply #2 on: May 20, 2019, 11:42:18 AM »
I have a totally manual homebuilt mill.  I stick a shim under a bunk.  8 feet of steel pipe for a lever and an assortment of shims accomplish the task for me.  For the occasions that I can't lift, I use a floor jack.  I do plan to do something different at some point.  At least that's what I told myself 15 years ago.
Wudman
Offline ljohnsaw
« Reply #3 on: May 20, 2019, 12:23:24 PM »
I started with a digging bar and shims for the small stuff.  The big stuff I needed my SkyTrak to lift to get a shim under it.  Then I found this:
It fits on the 4" channel of my log bunks.  Slow but works pretty well.
Then I picked up a bucket load of bottle jacks.  A little easier and a little faster.  Works good for me.
John Sawicky
Offline kng
« Reply #4 on: June 08, 2019, 09:29:55 AM »
Here's mine.  Just a Harbor Freight floor jack held by some angle iron.
2015 LT15G19 with Power Feed and custom trailer
« Reply #5 on: June 08, 2019, 12:20:02 PM »
Great solution !!
Stihl MS361
Stihl 026
Offline kelLOGg
« Reply #6 on: June 08, 2019, 07:17:31 PM »
My manual mill came with scissor jacks but I found they couldn't lift much so I replaced it with 2 manual hydraulic jacks. They are on bases welded 8' apart on the main mill rails. Much later I needed to saw a short fat sycamore so I added 2 more bases 4.5' apart. Each set of bases has a tool tray between them. So far that has covered all I need.
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Maple 2" Thick Green Live Edge Slab, and Bar Oil Substitutes
Started by jemmy on Sawmills and Milling
Last post October 03, 2018, 05:20:23 PM
by longtime lurker
types of chains
Started by L. Wakefield on Chainsaws
Last post March 21, 2002, 05:50:59 AM
by L. Wakefield
cable types
Started by postville on Forestry and Logging
Last post September 18, 2011, 06:03:29 AM
by HiTech
Chain types
Started by blade69001 on Chainsaws
Last post May 27, 2014, 08:10:47 AM
by Al_Smith
