Author Topic: Glue up  (Read 517 times)
Offline stumpy
  • I feel alot more like I do now than I did before
    • Rustic-woodfurniture/Stumpy's Wood Works
Glue up
« on: May 13, 2019, 04:23:51 PM »
looking for thoughts.  What is the lowest moisture reading acceptable for gluing up air dried wood for a table top?
White oak
Black Walnut
Also, same question but end gluing
I will be using dominos and Titebond 11.
Woodmizer LT30, NHL785 skidsteer, IH 444 tractor
Offline bwstout
Re: Glue up
« Reply #1 on: May 13, 2019, 05:04:10 PM »
I glued up a black walnut table top for a small kitchen island and a end table they were at 10 to 12% the small table top I did not finish under the bottom and it move came apart I made the second mistake and use pocket screws to hold it down and it could not move. The small end table I did finish on both side it did not come apart but did shrink. The best is ruff cut move inside and let it acclimate and it should be stable and allow it to move on the apron or legs. I have a large kitchen island and   a farm table that were 10 t0 12 and they are doing fine after 6 months they are pecan and the tops can move and they are finished on both sides. Right now I building a table from blue pine that is 11% will see how it does.
home built mill
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
Re: Glue up
« Reply #2 on: May 13, 2019, 06:37:34 PM »
Titebond says above 10% slows drying time.  Above 16 could be problematic.
Source:  http://www.titebond.com/resources/use/glues/faqs
Are you asking about gluing end grain?
lots of dull bands and chains
Offline Larry
Re: Glue up
« Reply #3 on: May 13, 2019, 09:35:00 PM »
Air dried wood here will be 16-20% MC.  I bring it inside for a couple of months before working it.  My target MC be it air or kiln dried is 10%.  At 10% I know which way it is going to move and how much.  Never had a problem gluing in the 10-12% range.
I normally use TB original or TB-3 if water resistance is required.  TB-2 is an outcast in my book.
Offline stumpy
Re: Glue up
« Reply #4 on: May 14, 2019, 07:34:36 AM »
what don't you like about TB 11
Offline stumpy
Re: Glue up
« Reply #5 on: May 15, 2019, 09:15:06 AM »
This is a bar top so I will be end joining due to the 30' length.  It's 1-3/4" black walnut joined end to end with glue, dominos and countertop clamps underneath.
Offline Larry
Re: Glue up
« Reply #6 on: May 15, 2019, 02:08:17 PM »
TB-2 is more expensive than the Original but doesn't have the resistance to water that TB-3 has.  TB-3 also has a longer open time than the other two.
Can you use calking glue to glue logs together?
Started by Rod on Timber Framing/Log construction
Last post February 28, 2005, 10:45:59 AM
by Rod
glue
Started by Dan_Shade on General Woodworking
Last post October 04, 2012, 09:41:13 AM
by Dodgy Loner
Glue-ups
Started by D._Frederick on General Woodworking
Last post March 27, 2009, 09:40:54 AM
by Modat22
Which glue?
Started by Brad_bb on General Woodworking
Last post January 01, 2012, 08:34:09 AM
by SwampDonkey
