Author Topic: 4 stroke slabber mill  (Read 516 times)
Offline Picky2016
  • I'm new but trying!
« on: May 14, 2019, 11:39:17 AM »
Well hello again gentlemen!
Built my first bandsaw mill here 3 years ago, tweaked it and built a second one with all the knowledge (and errors) from the first, still working great. I have a buddy who purchased a chainsaw mill that I modded to run on my track system. We were looking at retrofitting it with a vertical shaft 4 stroke (5-12hp) to make a mini slabber mill (20" logs and under). I searched on here and read the pros and cons, he's all right with them all. I already purchased a 36" bar and rip chain. I can't seem to find any photos of smaller ones. If anyone has any cluttering up their hardrives, could you post them for me please and I'll show them to him?
Build number 3 here we go!
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
Re: 4 stroke slabber mill
« Reply #1 on: May 15, 2019, 11:45:37 AM »
There won't be a whole lot of smaller mills using chainsaw bars like that since 36" and down has become bandsaw dominated based on speed and reduced kerf.
The upper end of that width range used to be price prohibitive, but there are several companies offering wide mills economically now.  (There are also bigger bandsaws than that that aren't terribly expensive.)  The chainsaw mills shine if extreme portability or very large (4-5' and up) cuts are needed.
A bigger one could be scaled down, but before you put a lot of time in, I'd recommend looking real hard at making or buying a wider band mill.
In the long run, you make your own luck good, bad, or indifferent. Loretta Lynn
Offline Picky2016
« Reply #2 on: May 23, 2019, 06:57:02 AM »
Well, while working on the 4 stroker, I dug out my old electric chainsaw. I bolted the 36" bar up, installed rip chain and bolted her in to my chainsawmill carriage. Cut a cedar slab off a 18" to try.
Is she slow? Yes. Does she cut? Yes. Merits some effort. Not sure how long the poor little 10 amper would last, but the neighbors didn't complain about any noise. Might dig out my old compressor replacement motor. Came across the Snik mill on YouTube. Nice electric mill.
Swing mill blade on 2 stroke cut off saw for an edger?
Started by slowmiller on Sawmills and Milling
Last post February 20, 2014, 08:59:17 PM
by trim4u2nv
Slabber vs bandsaw mill?
Started by Drebs on Sawmills and Milling
Last post May 08, 2018, 05:23:30 PM
by Drebs
Circular Mill vs. Slabber
Started by The MN Loon on Sawmills and Milling
Last post June 29, 2019, 06:41:32 AM
by Nomad
Lucas Mill Slabber question
Started by Kedwards on Sawmills and Milling
Last post September 04, 2006, 07:39:45 AM
by amberwood
