Author Topic: Why Didn't I think of that?  (Read 951 times)
Offline SawyerTed
  • Summey Lumber Services, LLC
« on: May 14, 2019, 05:02:51 PM »
Sometimes someone seeing a problem for the first time comes up with a good idea and I think, "Why didn't I think of that?"
Today I was sawing for a good friend.  He and The Doc were tail gunning.
The Doc often will use a long handled corn shovel to catch the sawdust.  She just walks along beside me and catches the sawdust so she's out of the way of a broken blade.  The sawdust gets dumped in a trash can or in a pile beyond the end of the mill for disposal later.  That way the pile of sawdust beside the mill doesn't have to be shoveled away and it doesn't kill the grass if we are sawing in someone's yard.
My friend is particular about his grass so he brought out the storage bins.  The bins caught the sawdust.  He and the Doctor dumped them when I was adjusting logs etc. When I was sawing cedar, Dan was all about saving the sawdust.
"Why didn't I think of that?"  I don't think I'll do this all the time but it did save a lot of shovel work.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
Re: Why Didn't I think of that?
« Reply #1 on: May 14, 2019, 05:16:56 PM »
I think that is most excellent.
Offline OffGrid973
  • Off Grid
« Reply #2 on: May 14, 2019, 06:52:33 PM »
The ones on wheels are good to drag right into the trailer as well when you are finishing up and drive off.
Cleanup is just as important when talking customer service...leave it as you found it, plus a whack or two :)
Your Fellow Woodworker,
- Off Grid
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #3 on: May 14, 2019, 07:40:52 PM »
Pretty clever idea!  ;)  8)
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Mossy Chariot
  • Forest Vue LLC
« Reply #4 on: May 14, 2019, 08:26:45 PM »
I like it. Thank you!!! 8)
Tony B
LT35HD, Kubota 3450, Wallenstein Skidding Winch, Stihl 250 & 460, can-am Defender
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #5 on: May 14, 2019, 10:06:34 PM »
   Neat idea. I like simple things. My last sawing was on the lot in front of my house where I want to protect the grass so I laid down 2 - 8X10 tarps overlapping a foot or so with a footpath between them and the mill. It worked pretty well and I bagged up the sawdust for oil sweep for a couple of people who wanted some. Big open bins would be easier to fill than 50 lb feed sacks but I had plenty of feed sacks available.
Offline SawyerTed
« Reply #6 on: May 15, 2019, 09:07:45 PM »
I've tried several things including tarps.  Besides catching the sawdust with the big shovel, this has worked as well as anything.  Of course the shovel method requires a long handled shovel and a person to operate it. :D
My next thing is a slab processor!
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #7 on: May 16, 2019, 04:03:36 PM »
nuff said
Jim Rogers
« Reply #8 on: May 16, 2019, 05:40:37 PM »
   I tried the bucket trick but it conflicted with my wheel every time we'd pass it when getting low.
Offline Lawg Dawg
  • True South Sawmill Lumber
« Reply #9 on: May 16, 2019, 09:21:52 PM »
I like this way too!
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
 John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
I bet you didn't see this on Ax Men
Started by tim1234 on General Board
Last post June 24, 2008, 11:53:06 AM
by rebocardo
Didn't know it would fit.
Started by customsawyer on Sawmills and Milling
Last post October 20, 2016, 11:03:18 AM
by Ga Mtn Man
The One That Didn't Get Away!
Started by EZ on The Outdoor Board
Last post June 28, 2005, 09:01:37 PM
by EZ
cheesy
I didn't know that.
Started by DR_Buck on General Board
Last post January 11, 2018, 01:06:12 PM
by DR_Buck
