Author Topic: advice on saw blade  (Read 598 times)
Offline JMG
advice on saw blade
« on: May 14, 2019, 09:13:07 PM »
I have always run 10 degree all purpose wood mixer blade on my lt40 mill gas engine.been getting a lot of extremely knotty logs 24" to 30".had a box of winter blades tried a T7 blade seem to slide right through the knots anyone else run this blade.how is it in the long run?.getting a lot of dipping on my half wore out 10 degrees
JMG🚜
Offline Southside
Re: advice on saw blade
« Reply #1 on: May 14, 2019, 09:18:55 PM »
Turbos are kryptonite for 10's, no comparison.
Offline Beavertooth
« Reply #2 on: May 14, 2019, 09:59:12 PM »
I run only turbo 7 on everything and this is after using 10s 7s 4s and 9s.  It really is  a do all blade. At least here in the south. Cuts soft or extremely hard wood great. Don't know anything about sawing frozen logs.
2007 LT70 Remote Station 62hp cat.
Offline Southside
« Reply #3 on: May 14, 2019, 11:05:02 PM »
Going to a 1.5" will help a lot too if your mill can run them.
Offline Beavertooth
« Reply #4 on: May 15, 2019, 06:35:34 AM »
Don't know what horsepower engine you have but if you have say a 38hp Kohler gas you can run the .050 instead of the .045 blades and push them harder. I use to have a LT40 with 24hp Onan and I put the 38hp Kohler gas and it ran the ..050 just fine.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: May 15, 2019, 07:34:37 AM »
1" .045 Turbo 7's all of the way for me.  I tried the 1" .055 T7's but they broke much sooner.  :-X   I have never tried a 1" blade, but as mentioned above, the 1" .050 T7's should be a winner.
I still have a few 4 blades but it has been well over a years since I put one on the mill.  The T7's will saw Post and White Oak so I have no need for them.
need advice on blade
Started by cluckerplucker 1 on Sawmills and Milling
Last post February 02, 2008, 06:24:47 PM
by Fla._Deadheader
Blade advice
Started by strunk57 on Sawmills and Milling
Last post January 05, 2014, 11:19:15 AM
by drobertson
Blade advice
Started by Engineer on Sawmills and Milling
Last post August 29, 2015, 10:37:37 AM
by 4x4American
D&L swing blade advice needed
Started by Mt406 on Sawmills and Milling
Last post October 11, 2013, 10:31:05 PM
by Mt406
