Author Topic: Price on ash flooring  (Read 613 times)
Offline bulldozerjoe
« on: May 15, 2019, 09:02:48 PM »
if I need 1100 square feet of 4 inch t@g flooring... how much board feet would I need to bring to the mill... it would be my logs and the mill would have to saw, dry, and mill... also how much would you charge to do this for me... thanks Iím just trying to figure out a flooring project, what it takes and money involved, thank you
New holland tc 45
Fransguard 4000
Sthil 021-028super-029-066
Online Southside
Re: Price on ash flooring
« Reply #1 on: May 15, 2019, 09:08:32 PM »
The grade you are after in the final product and grade of your logs is a big factor in the conversion.
Even for straight mill run you are looking at 30% bare minimum of loss due to the process.
« Reply #2 on: May 15, 2019, 09:10:29 PM »
Iím not looking for any grade in perticular... just knowing the lumber came from out back...
New holland tc 45
Fransguard 4000
Online Southside
« Reply #3 on: May 15, 2019, 09:33:59 PM »
All one size will also limit yield %.  A random width like 3,4,5 or 4,5,6 will give you a better yield.
Offline rooster 58
  • GRIZ, the sawmill mgr.
« Reply #4 on: May 15, 2019, 11:21:11 PM »
And figure 25% waste from the dried material, from removing checks, rot and such. And from straight line ripping the lumber into strips
Offline DRB
« Reply #5 on: May 16, 2019, 02:50:25 AM »
If it was me I would take logs that scale at least 2200 bd ft.  You will probably have a little left over but thats better then being one board short.
« Reply #6 on: May 16, 2019, 09:29:57 PM »
id figure id send the mill 2800 bf, im not going to run out..... any buddy got a going rate on sawing, drying and milling?
New holland tc 45
Fransguard 4000
Offline ellmoe
« Reply #7 on: May 17, 2019, 06:13:43 AM »
  For most species and sizes we charge $1.50/bf.
Slab Price vs Dimensional lumber Price
Started by Solar_HoneyBee0 on Sawmills and Milling
Last post May 07, 2019, 08:21:00 PM
by Tom the Sawyer
Oak Flooring
Started by g_man on Forestry and Logging
Last post September 30, 2011, 06:13:13 PM
by 250quality
Flooring
Started by MikeB on Drying and Processing
Last post July 11, 2006, 01:29:21 PM
by footer
flooring
Started by donald_harby on Wanted
Last post May 02, 2007, 08:26:44 AM
by donald_harby
