Author Topic: Spring planing  (Read 617 times)
Offline Quebecnewf
Spring planing
« on: May 16, 2019, 04:34:55 AM »
A lot of people are starting their spring planting , were into spring planing .
We planed up around 2800 ft of 2x4 and 2x6 plus a bit of 2x8 yesterday . Pic shows the lumber after the first pass.
We then passed the 2x6 back through the old Poitras three sided moulder planer to end up with it all dressed four sides. Will do the 2x4 when the weather changes for the better ( wet snow) here today.
Those old sawmill planers just blow me away . You keep them sharp and you can throw anything to them and they just sit there and chew through it .
The old Poitras turns out beautiful smooth dead straight lumber . As soon as you get a pile planed you have to force yourself not to build another shed just as excuse to work with the wood .
Quebecnewf
Online Chuck White
  • Sawing Mobile since 2005
Re: Spring planing
« Reply #1 on: May 17, 2019, 10:41:25 AM »
Looks like quite a project!
The crappy weather doesn't help anything!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline DDW_OR
Re: Spring planing
« Reply #2 on: May 18, 2019, 03:25:10 PM »
.........As soon as you get a pile planed you have to force yourself not to build another shed just as excuse to work with the wood .
Quebecnewf
well you do need a new large covered area to work 8)
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
1st Planing Job
Started by Fla._Deadheader on Sawmills and Milling
Last post August 06, 2004, 03:52:13 PM
by woodbeard
Planing
Started by sawwood on Drying and Processing
Last post March 28, 2009, 02:41:50 PM
by sawwood
Planing, T/G
Started by CX3 on Drying and Processing
Last post January 01, 2016, 03:51:28 PM
by scsmith42
planing beams
Started by nh-dan on Timber Framing/Log construction
Last post July 07, 2015, 09:03:20 PM
by Wudman
