Author Topic: Chainsaw mill stretched chain, is it junk?  (Read 467 times)
Offline Brad_bb
« on: May 16, 2019, 10:50:05 AM »
A year or so ago I bought a ripping chain for an early 80's era granberg mill I bought with a 56" bar. It takes .404 chain.  I've milled 5 logs with it.  Now the chain is stretched such that there is no more adjustment in the saw head(090) to tighten the chain.  The cutters are not near the end of their life, but because of this stretch, does that mean the spacing between the drive teeth is now too long and will have problems with the drive sprocket?  Do I need to replace this chain with a new one, or can I remove a link? I watched a youtube video where the guy said that if a chain is stretched beyond adjustment, that removing a link to tighten will not work because the distance between drive teeth will be too far off.  He had a smaller chain for a 16 or 18" bar he was demonstrating with.  But given that my chain is so long, it takes much less wear in each link for the chain to stretch like that than if it were a much shorter 20" bar chain for example.  So maybe I can remove a link and continue using it?  Though i would not want to remove another one after that.  Anyone have any knowledge on this?
Offline jimparamedic
Re: Chainsaw mill stretched chain, is it junk?
« Reply #1 on: May 16, 2019, 11:04:08 AM »
With that long of chain you should be ok removing a link. It can also be tip wear if you don't have a secondary oiler on the tip.
Offline Brad_bb
« Reply #2 on: May 16, 2019, 11:28:49 AM »
Yes I have a secondary oiler and roller tip.  A new ripping chain for this mill is about $130, so I would like to get good life out of it.  Cutting Hardwoods.
Offline sawguy21
« Reply #3 on: May 16, 2019, 11:40:03 AM »
You will be fine. I have never seen a chain stretched so badly it would cause a drive sprocket problem.
Offline Old Greenhorn
« Reply #4 on: May 16, 2019, 11:49:03 AM »
Quick and maybe stupid question Brad: Are you sure it's the chain and not that the drive sprocket is shot? This seems like an awful lot of stretch. but it is a long bar.
Can You help out the Coleman Veterans Memorial by chipping in a few bucks? Go here for the full story: Can you help this year? in General Board
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here.
Offline Brad_bb
« Reply #5 on: May 16, 2019, 12:02:27 PM »
Sprocket was new when chain was put on.
Offline John Bartley
  • Location: 13 Critchley Avenue, PO Box 36, Monteith Ont, P0K1P0
« Reply #6 on: May 16, 2019, 03:44:44 PM »
Just want to throw this out there ... some may disagree ... and yes, it's a bit of nit picking semantics, but ...
Chainsaw chains don't stretch. They wear at the rivets where they pivot to go around the sprocket and tip. The longer the chain, the less individual rivet wear it takes to accumulate enough extra length to make it difficult to adjust the chain and that's what we call stretch.  In this case, given the long length of the chain, removing a link is probably quite safe.
The only reason I bring this up is because over the last thirty years of selling and servicing chainsaw, I have had customers come to me with so much wear on their chains that I could almost break the chains by hand ... not really safe, and these customers had been told that it was OK to remove a link.  Before removing a link, please make sure it's safe.  Broken chains rarely cause injury, but it does happen.
cheers ... back to your regular programming .. :)
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
Offline Brad_bb
« Reply #7 on: May 17, 2019, 02:48:14 PM »
Yes, that's what I was thinking- long chain, only a little wear will cause significant stretch.  Granberg also emailed me back saying it'd be ok to take out a link.  Ya'll confirmed what I thought.  Chain is in good condition otherwise- a few broken teeth, but overall good shape.  Broken ones will just have the top of the cutter broken off.
I removed a link last night.  The Granberg break n mend tool wasn't the easiest to use.  It's supposed to press/break the rivet out with a vicegrip actuated pin and anvil.  One worked as it was supposed to, but  two others just didn't want to snap.  I used a dremel and cutoff wheel to grind the one head off and then remove the section I wanted to (4 rivets).  I installed the new connector link and I did manage to smush the rivet heads, but wasn't as easy as I thought it was going to be.
Offline welderskelter
« Reply #8 on: May 17, 2019, 03:39:21 PM »
Not familiar with Granberg but do they work like stihl so you could just put on a bigger drive sprocket?
Ripping chain for a chainsaw mill
Started by Beefie on Sawmills and Milling
Last post December 14, 2013, 09:42:55 PM
by HolmenTree
ChainSaw mill pinching chain
Started by fenris on Sawmills and Milling
Last post November 02, 2015, 05:17:30 PM
by Kingmt
question
Request Chainsaw , bar and chain advice for a Logosol Big mill
Started by woodlearner on Sawmills and Milling
Last post April 01, 2013, 11:05:57 PM
by piller
Chain Jumping with Harvester Sprocket on Chainsaw Mill
Started by Boilermaker007 on Sawmills and Milling
Last post February 09, 2017, 09:30:08 AM
by Boilermaker007
