Author Topic: forklift problems  (Read 520 times)
Offline xlogger
forklift problems
« on: May 18, 2019, 06:24:05 AM »
Things keep going south for me lately. My old 584 case forklift has been sticking in reverse somewhat for over a year now, with a little taping on peddle it quits but Thursday at the end of the day it stuck for good. I removed the linkage and its for sure in the transmission. I found a mechanic in Va that knows about them and he said if I'm lucky a fork bend inside but he  thinks it worst than that. I'm out of town now but will remove the top plate of the transmission nest week and see if I can see the problem (I'm no mechanic). I'm started looking for a replacement but  for now I do have a tractor with FEL and bobcat to get by. But will sure miss the power of the forklift.
Offline xlogger
Re: forklift problems
« Reply #1 on: May 21, 2019, 05:53:10 AM »
Does anyone here have one of those forklifts like they use on docks but have larger air filled tires? They say they good on gravel, wonder how they do on areas with loose crush and run gravel? Or up a hill with hard base clay and rock?
Online hedgerow
« Reply #2 on: May 22, 2019, 06:03:28 PM »
xlogger
A friend of mine had one like your talking about with the air filled tires and it worked pretty good were his rock drive was hard. They mostly used it on concrete. They sold it later as it didn't work well in loose rock or in the spring when the drive was soft. A tube mill went out of business about 10 miles from were he lives and they had a 20,000 pound lift it may be rated more than that I will look the next time I am at his place. Its on triple truck tires in the front and single in the back. They used it to unload and move coils of steel around. That thing is a beast but loves soft ground.
Offline xlogger
« Reply #3 on: May 24, 2019, 05:25:43 AM »
I'm thinking I might look at the moffetts, Tom the Sawyer here has one and we pm about it and he is happy with his.
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
« Reply #4 on: May 24, 2019, 12:57:19 PM »
Mine is actually a Princeton Teledyne.  Several companies make similar models, Manitou, Moffett, Palfinger, LoadMac, Navigator, Sellick, Donkey, Tailgator, etc..  Found mine used on Machinery Trader.
07 Timberking B-20, Custom-made log arch, 20' trailer w/ log loading arch, F350 SD flatbed dump.  Princeton piggy-back forklift.  Bobcat S250, Stihl 025C 16" and a Husqvarna 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says "He's sawin logs", I ain't snorin'.
Forklift
Started by PoDunk on Sawmills and Milling
Last post February 23, 2010, 12:36:11 PM
by ForestMan
using forklift
Started by xlogger on General Board
Last post July 01, 2016, 07:07:00 AM
by gspren
3pt forklift
Started by ahlkey on Sawmills and Milling
Last post April 12, 2011, 01:35:34 PM
by ahlkey
forklift
Started by Possum Creek on Sawmills and Milling
Last post April 29, 2015, 10:36:57 PM
by Possum Creek
