Author Topic: Trailer build for HM126  (Read 2433 times)
Offline Dana Stanley
  • For fun and profit!
    • Yankee Wood Signs
« on: May 27, 2019, 06:56:40 PM »
Started the trailer for my mill. It's about 10" wider as that was the smallest axle I could find, and if I ever upgrade I will be good to go. I had some scrap c channel, but bought 2x4 box tube for the rails and ends. I bought 6 - 2000 lb jacks, 2000 lb axle, tires, lights, and coupling; I should have around $700.00 into it when I'm done. Because I have no way to fixture it I have a bit of an arch in it from welding the axle on, I may try to heat it out, but the way I planned on mounting the track will allow me to adjust the track on the trailer if I need to. This is about 12 hours into it.
Making Sawdust, boards and signs.
Woodland Mills HM-126
Kabota B-7800 with backhoe and loader
Ford Ranger, Husqvarna 455 20", Mac 610 24", other chainsaws 14"
Matthew 3:10
    • Yankee Wood Signs
Re: Trailer build for HM126
« Reply #1 on: May 28, 2019, 06:49:13 AM »
After thinking about it, I will probably try heating the other side of the rail to get the arch out. I will flip it, support it on the ends again, weld the tabs that hold the track on, and if that doesn't help I can use a rose bud to heat it dark red above the offending welds (600 degrees). Any advise?
Matthew 3:10
Online btulloh
« Reply #2 on: May 28, 2019, 07:49:56 AM »
If you can't get the arch out of the rail, you may need to shim to saw tracks.  That might be the ticket anyway.  It might be a good idea to mount the track on the rails so that it can be adjusted in the same way as the feet work, but through-bolted.
Looks like the trailer is coming along nicely.
HM126
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #3 on: May 28, 2019, 07:53:10 AM »
I don't see to much reason you need to straighten the trailer. is the sawmill is going to be bolted to it and adjustable? If so I would not mess with straightening. Just make sure you have adjustment in the bolt holes.
Looks good. Looks to me like your axle is upside down. the curve should be up. but I guess in such a light application it doesn't really matter.
Offline doc henderson
« Reply #4 on: May 28, 2019, 07:53:42 AM »
I had that problem on a scout trailer for fire wood (6 x 10 x 2 foot tall sides).  I did not notice it until after sides were welded and it has a permanent arch.  I should have supported under the axle while welding.  It works fine, and is noticed mostly by me!  I am sure you will figure it out.
timberking B 2000, 277c track loader, PJ 32 foot gooseneck, 1976 F700 state dump truck, JD 850 tractor.
Offline luap
  • Not as good as I once was
« Reply #5 on: May 28, 2019, 08:47:12 AM »
If you have an air compressor, get an pneumatic peening tool and peen your welds and that will relieve some of the stress from the weld. I have also seen a heat and quench method used to take warpage out much like auto body dent repair. Just heating will be hard to control and to get the two sides the same.
Offline goose63
« Reply #6 on: May 28, 2019, 09:02:53 AM »
When I made mine I used 2x4x1/4 tube the frame did not arch at all
goose
thank you to all the vets
Offline olcowhand
  • I'm new- ish!
« Reply #7 on: May 28, 2019, 05:17:14 PM »
Hey Goose,
I use cans like the one on the Trailer frame for "Welder Prep", too.
They say the mind is the first to go; I'm glad it's something I don't use!
Ezekiel 36:26-27
« Reply #8 on: May 28, 2019, 05:22:16 PM »
Ol cow hand, i think that was just for scale :D :D, and I assume it preps the guys doing the welding, not the material.   smiley_beertoast
Offline luap
« Reply #9 on: May 28, 2019, 07:03:24 PM »
Looking at the picture now, The spring shackle welded on right where the cross member is welded on has contributed to your stress problem .I would leave it alone and correct wherever the mill bolts on with shims if necessary.
    • Yankee Wood Signs
« Reply #10 on: May 28, 2019, 07:39:26 PM »
Ya, good catch, I need to put the axle on top of the spring, not below, what a maroon aye!
Matthew 3:10
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #11 on: May 29, 2019, 07:03:49 AM »
when I built my mill i used an old horse trailer axle and the wheels and tires that were on it. I now have a tire wheel combo that I have to be very careful with. if I do not raise the jacks far enough I can slice the top of the tire clean off with the mill. Watch out for that on your trailer build.
Offline olcowhand
  • I'm new- ish!
« Reply #12 on: May 29, 2019, 05:24:22 PM »
Hey Doc,
In this case, the term "Welder" can have two meanings: The Machine & "The Guys doing the Welding". You definitely are on the right track.....
Ezekiel 36:26-27
    • Yankee Wood Signs
« Reply #13 on: May 29, 2019, 08:22:50 PM »
I've been banned from using welder prep, for 30 years now, or I would have had a few cans for scale too! If I still used it there would be more incidents like the axle, which I corrected today!
Matthew 3:10
    • Yankee Wood Signs
« Reply #14 on: May 30, 2019, 10:55:59 PM »
More issues with the axle. Turns out 13 inch tires are deeper than what is usually used on the axle, which put the tire against the frame. I had to widen the axle and move the spring mounts. Another 1-1/2 Hours
Matthew 3:10
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #15 on: May 31, 2019, 07:11:38 AM »
that looks good. at least trailer axles are easy to fix...
    • Yankee Wood Signs
« Reply #16 on: June 01, 2019, 08:44:24 PM »
Added the Jacks, and the track mounting tabs today. I had some 3x6x1/4" angle and used that for the tabs. 8 hours today 14 tabs, 6 jacks. The arch isn't as bad, but it is still there, I'm still thinking about heating it opposite the shackle welds to try to get it a little straighter!
Matthew 3:10
« Reply #17 on: June 01, 2019, 08:48:07 PM »
looks great Dana, always takes longer than expected, esp. if you maintain high standards.
Offline goose63
« Reply #18 on: June 01, 2019, 08:51:09 PM »
Dana that trailer is looking mighty good 8)
goose
    • Yankee Wood Signs
« Reply #19 on: June 01, 2019, 08:55:41 PM »
Ya, it looks like a few hours of work, but the band saw only moves so fast, and I was trying to keep everything as square and flat as possible. I also ground 45s in all the tabs and in the channel where I mounted the jacks, to get good solid welds. Not sure if I want to weld the track bolts to the tabs, or weld the track mount plates to the tabs, or through bolt it! That was my original plan, but welding is a lot less work than drilling. Through bolting would probably be the strongest, then next strongest would be welding the plates with the bolts already in them!!
Matthew 3:10
A New LT 10 and Trailer Build
Started by Slingshot on Sawmills and Milling
Last post March 28, 2016, 07:22:11 PM
by Kbeitz
Another new sawmill trailer build (HFE-21)
Started by Verticaltrx on Sawmills and Milling
Last post March 21, 2015, 12:40:20 PM
by Peter Drouin
WM LT10 Trailer build.
Started by OlJarhead on Sawmills and Milling
Last post August 07, 2013, 12:34:53 PM
by OlJarhead
Sawmill trailer build
Started by JD Picket on Sawmills and Milling
Last post March 10, 2017, 06:42:02 PM
by fishfighter
