Author Topic: Trailer build for HM126  (Read 1516 times)
Offline doc henderson
Re: Trailer build for HM126
« Reply #20 on: June 01, 2019, 09:27:28 PM »
If some one had an old pirrana metal muncher punch, see what they would charge to punch the holes. trade them some sawing ect, unless you need the holes on parts already on the mill.  then take a mini bench top drill press and rig it up on the mill.
timberking B 2000, 277c track loader, PJ 32 foot gooseneck, 1976 F700 state dump truck, JD 850 tractor.
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #21 on: June 01, 2019, 09:45:53 PM »
Can you spin the handle all the way around on your jacks? I have a couple that I have to hold them up cause the log bunks. It is very annoying. You are not going to like it if that is the case.
Looks good though.
Offline Bruno of NH
« Reply #22 on: June 02, 2019, 05:22:29 AM »
Can you take the jack handles off and weld a nut on top and use a 1/2" cordless impact to raise and lower it ?
thomas 8013 mill, Riehl Steel edger,Mahindra 3540 cab tractor loader F350 4x4 dump and lot of contracting tools
Offline Dana Stanley
  • For fun and profit!
    • Yankee Wood Signs
« Reply #23 on: June 02, 2019, 08:23:55 AM »
Looks good though.
Like Bruno said, my plan is to install coupling nut, like for threaded rod in place of the handles. Then I can use a socket in a twist driver (forget the real name) or a cordless drill. I may get an cordless angle drill, , and use it to raise and lower the mill head too.
Making Sawdust, boards and signs.
Woodland Mills HM-126
Kabota B-7800 with backhoe and loader
Ford Ranger, Mac 610 24", other chainsaws 14 to 20"
Matthew 3:10
Offline luap
  • Not as good as I once was
« Reply #24 on: June 02, 2019, 08:24:40 AM »
I think the track mounting should be bolted as you said was your original plan. Any future adjustments will be easier to deal with than grinding off welds. A magnetic base drill would be just the thing for drilling many holes. Maybe a local tool rental would have one?
Offline Ed_K
« Reply #25 on: June 02, 2019, 09:39:19 AM »
 X2 what luap said. Sooner or later a big log will get dropped on or large cant turned and the weld broken. Bolt will be easier to replace.
Ed K
    • Yankee Wood Signs
« Reply #26 on: June 04, 2019, 07:04:10 AM »
I ordered 5/8" rod couplings (long nuts) for the trailer jacks. I got a bag of 25 for $23.00 not sure what I will do with the extra, but I am sure I will use them sooner or later. They wanted $16.00 for 6. Going to Americade so I won't be able to work on it this weekend.
Matthew 3:10
Offline ktm250rider
« Reply #27 on: June 07, 2019, 02:39:31 PM »
yeah same comment here.  My handles interfered with my carriage and blade guard when I was down to 1" cut above the bunks.  I added a 4 inch spacer and still need to remove the handles.  I like the nut/drill idea.  May have to "borrow" that.
Offline ljohnsaw
« Reply #28 on: June 07, 2019, 11:30:46 PM »
I think you mean a speed wrench?  Kind of like an old brace drill.
John Sawicky
A New LT 10 and Trailer Build
Started by Slingshot on Sawmills and Milling
Last post March 28, 2016, 07:22:11 PM
by Kbeitz
Sawmill trailer build
Started by JD Picket on Sawmills and Milling
Last post March 10, 2017, 06:42:02 PM
by fishfighter
log trailer build idea
Started by bigred1951 on Forestry and Logging
Last post March 21, 2013, 09:10:28 PM
by chevytaHOE5674
Sawmill Trailer Build
Started by Timberline on Sawmills and Milling
Last post July 04, 2013, 09:51:14 PM
by Herb Brooks
