Author Topic: Hickory Door  (Read 2096 times)
Offline Bindian
  • Gender: Female
Hickory Door
« on: May 28, 2019, 12:17:06 AM »
Within two years, I will be building  a log home.  I'll build the front door out of Hickory.  Two weeks ago, I had to cut down a beautiful Hickory tree.  Now, should I cut it into boards now and stack and sticker to store above my barn shop, or just keep the log off of the ground for up to two years?
hugs,  Brandi
Mahindra 6520 4WD with loader/backhoe and a Caterpiller E70 Excavator.  My mill is a Woodmizer LT40HD Wide Diesel.
Offline WLC
Re: Hickory Door
« Reply #1 on: May 28, 2019, 12:45:18 AM »
I'd saw it now, stack and sticker.
Woodmizer LT28
Branson 4wd tractor
Stihl chainsaws
Elbow grease.
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
Re: Hickory Door
« Reply #2 on: May 28, 2019, 07:05:57 AM »
I'd cut it now and cut it a little thick and stack and sticker it with a lot of weight.
You never know what hickory wants to do, I haven't cut a lot of it but what I have noticed is that the bigger the tree the straighter the wood when you mill it.
I recently cut a 12" and it cupped in 2 different directions on the same board!!!
I wound up using it for smoking wood.
Jon
Imagine, Me a Tree Farmer.
Jon, Appalachian American Wannabe. ... and it looks like my dream will come true!
Offline Bindian
  • Gender: Female
Re: Hickory Door
« Reply #3 on: May 28, 2019, 10:01:53 PM »
Thanks Guys!  I cut it ASAP.
hugs,  Brandi
Offline Bindian
  • Gender: Female
Re: Hickory Door
« Reply #4 on: May 28, 2019, 10:06:52 PM »
Will 7 degree blades saw it, or will I need a blade in another degree?
hugs,  Brandi
Offline nativewolf
Re: Hickory Door
« Reply #5 on: May 28, 2019, 10:13:02 PM »
PPB love hickory so be sure to spray boards with borate.  Another reason to saw.  A reason not too would be that Hickory stains badly in hot weather.  For this reason there is generally no commercial hickory log sale from May to September.
Liking Walnut
Offline Bindian
  • Gender: Female
Re: Hickory Door
« Reply #6 on: May 29, 2019, 01:55:15 AM »
What is PPB?  Never heard of it down here in Texas.
 I had to cut it down ASAP, as it looked like it was gonna uproot onto my friend's trailer.  He has phobias of leaning trees, as Harvey uprooted one on his RV trailer.  We were out in Harvey's full force trying to get the tree off of his RV, while trying to keep my 4WD Mahindra from sinking up to the axles, then tarping the trailer.......................not fun at all.
hugs,  Brandi
Offline LeeB
Re: Hickory Door
« Reply #7 on: May 29, 2019, 02:10:23 AM »
Powder Post Beatles, and they do exist in Texas.
Re: Hickory Door
« Reply #8 on: May 29, 2019, 07:37:35 AM »
hugs,  Brandi
I cut mine last year using a Woodmizer 7 Degree blade on my Norwood manual mill. I had no problems. It was a pretty big tree and straight I got 5 9' saw logs out of it.
Jon
Offline Bindian
  • Gender: Female
Re: Hickory Door
« Reply #9 on: May 29, 2019, 07:44:13 AM »
But do they exist in Southeast Texas with all our humidity?  We have Pine Burrow (Bore?) Beetles here big time.
hugs,  Brandi
Offline Bindian
  • Gender: Female
Re: Hickory Door
« Reply #10 on: May 29, 2019, 07:46:37 AM »
hugs,  Brandi
Jon
Thanks.  I found another thread on Turbo 7s and others cutting dry and green Hickory.
hugs,  Brandi
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Hickory Door
« Reply #11 on: May 29, 2019, 08:00:10 AM »
Powderpost beetles love the South.  Nativewolf's advice to spray with borate is spot on.  Like has been said, it if is hot with no air flow, hickory will blotch with an ugly gray stain.  Also saw it soon as the ambrosia beetles also love hickory and will riddle the log with little black lined holes.  Powderpost beetles only infest the dry lumber whereas ambrosia beetles infest the green log.
Offline Raym
Re: Hickory Door
« Reply #12 on: May 31, 2019, 04:15:44 AM »
Sorry to pop your balloon but I would not build your front door out of any wood much less hickory. As a builder I do not recommend even installing commercially made wooden doors but if a customer insists, they must sign a wavier. The problem is that the margins required for an entry door are very small and the slightest movement will result in unconditioned air making its way inside an otherwise "tight" house. If you install a wooden door, it WILL move, warp, twist, all the bad things......you cannot avoid this as you have one side conditioned and the other exposed to outside elements.
I would suggest use your hickory for a feature barn door inside and install a commercial fiberglass or steel exterior door.
Just my opinion.
'14-LT40 super, nyle l200m kiln, vintage case 480E loader.
It's not the fool that askith, it's the fool that agreeith.
Offline Bindian
  • Gender: Female
Re: Hickory Door
« Reply #13 on: May 31, 2019, 06:56:16 AM »
Just my opinion.
Thanks for you input.  But there are several ways to build a door that can minimize what you have waivers signed for.   Challenge accepted.
    hugs,  Brandi
Offline LeeB
Re: Hickory Door
« Reply #14 on: May 31, 2019, 07:30:53 AM »
 :snowball:
:D popcorn_smiley
Offline Bindian
  • Gender: Female
Re: Hickory Door
« Reply #15 on: May 31, 2019, 12:35:33 PM »
Can I use a solution of water and Borax, the 20 Mule team variety?  I found how to use it here.... https://www.hunker.com/13425952/how-to-treat-wood-with-borax
hugs,  Brandi
Offline Bindian
  • Gender: Female
Re: Hickory Door
« Reply #16 on: May 31, 2019, 11:35:24 PM »
I have 2006 square feet of hickory flooring in my shop.  Should I spray it with borax also?
hugs,  Brandi
Offline LeeB
Re: Hickory Door
« Reply #17 on: June 01, 2019, 12:06:05 AM »
That would stop any new infestation but won't help if they are already there. Not sure what the water will do to the boards as far as warp/cupping goes depending on how dry it already is. Some of the others will have to chime in on this.
Offline nativewolf
Re: Hickory Door
« Reply #18 on: June 01, 2019, 06:34:38 AM »
hugs,  Brandi
Jon
That's a nice tree.
Liking Walnut
Offline tacks Y
Re: Hickory Door
« Reply #19 on: June 01, 2019, 07:17:57 AM »
I put a fiberglass door on my house when I built it, lasted 10-15 years. Now I have an oak door I made, just as old and still good. I made my door with 3 layers of oak not single 2". Go for the hickory.
Door for 1984 or 85 Timberjack 240A (DOOR FOUND)
Started by Rob-IL on Wanted
Last post August 24, 2010, 05:56:07 PM
by Rob-IL
3 sided husk on hickory nut - what type of hickory is it?
Started by Lanier_Lurker on Tree, Plant and Wood I.D.
Last post August 25, 2007, 09:18:14 AM
by Lanier_Lurker
Red Hickory (Pignut Hickory) value?
Started by jbburd on Sawmills and Milling
Last post July 18, 2007, 08:37:00 PM
by jbburd
new door
Started by Texas Ranger on General Woodworking
Last post September 03, 2008, 04:24:44 PM
by Dodgy Loner
