Author Topic: Official 2019 16th annual PiGROAST RSVP topic.  (Read 10543 times)
Offline goose63
Re: Official 2019 16th annual PiGROAST RSVP topic.
« Reply #160 on: August 06, 2019, 05:01:09 PM »
I sure did! Some friends of mine in the music store business gave me an EXTREMELY good rate on a Bass and Amp for the weekend. Danny liked it!
Now Danny me thinks you were one of those telling me if win the grand prize Iwould have to play itand now a year later I find out you can play and you did'nt play mine shame on you ;)
goose
thank you to all the vets
Offline RichTired
« Reply #161 on: August 06, 2019, 06:04:50 PM »
I would also like to add my thanks to Jeff & Tammy, his family, friends and neighbors who helped put on this event!
This was my very first FF Pig Roast and I enjoyed it all.  Good fellowship, Great food, and prizes to boot.  It was worth the 1750 mile round trip from Alabama to Harrison, MI.
I would also like to thank all the FF sponsors who provided support or door prizes.
Jeff visiting with some of the guests.
Resonator and Jeff jamin'
Wood-Mizer LT15GO, Kubota L2800, Husqvarna 268 chainsaw, Logrite cant hook, Ford F-150 Fx4
Richard
Offline Howdy
« Reply #162 on: August 06, 2019, 06:11:48 PM »
Please enlighten those of us who were unable to attend this year:
What games were played and what prizes were won?
How many people attended?
Did Tammy walk around carrying any big cabbages?
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #163 on: August 06, 2019, 07:20:08 PM »
Jeff constructed a "Plinko" like game, where each contestant was given 3 cedar disks to roll on edge down a ramp. These went across concrete, and into wooden slots marked with + and - numbers, the total of the three giving the score. Hats, key chains, pencils, backpacks, flash lights, toy chainsaws, ceramics, band saw blades, and a Log -Rite log lifter were among the prizes. The grand prize was a Stihl backpack style leaf blower. I would rough guess 75 - 100 total on Saturday, including Jeff's family, friends, and neighbors. The only cabbage I heard mention of was in the boiled dinner. There was a "surprise guest" who appeared during the Plinko game, hopefully someone got a picture! :D
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #164 on: August 07, 2019, 03:14:27 PM »
Thanks to all that a part in making this year's pigroast a great time!   I'm just getting back after having left with Steve Beecraft Sunday afternoon to go to the cabin for a few like in the olden days!  Had a great time. We picked almost everything up that was in the yard before we left. Always lots of help when we need it. :)   Now its time to catch back up and convert the pig roast central pole barn back to being just a garage and pole barn and shop. :)  The yard was surprisingly long after having such a workout just 3-4 days before. Harley missed me. Tammy did too. :)
I also have to now dig up my well. >:(
Offline Jeff
  • Fearless Leader
« Reply #165 on: August 07, 2019, 03:41:26 PM »
oh!  Quick mention in case anyone was wondering. The surprise appearance was known of in advance by the surprise appearance subject. ;)
Offline LAZERDAN
« Reply #166 on: August 07, 2019, 07:50:38 PM »
You have to dig up the Well, Hole in the pipe, between the well and the House.??        Lazerdan
Offline Jeff
  • Fearless Leader
« Reply #167 on: August 07, 2019, 08:59:56 PM »
THe pump kicks on every few minutes for a few seconds when there is no call for water. Very low pressure until the pump kicks on, then it is normal. The sprinkler system is designed to take enough water to keep the pump running, so that is the only time we get good pressure to take a shower. Otherwise, it is bad, then good, then bad, then good.
This is a pvc well. Buried bladder tank which I feel is probably the issue plus there must be a leak due to the pump kicking on when there is no water call.
Offline Mike W
  • Location: Boundary Washington - Right on the edge of the Northern Boarder
« Reply #168 on: August 07, 2019, 09:40:03 PM »
Little or no water pressure until the pump engages is most likely the failed bladder in your pressure tank, by the sounds of your issue, might be one in the same.  a hole in the pressure tank with failed bladder will give you those symptoms, pressure with the pump running and little to no pressure with it in static mode.  Most we have worked on with that issue was an internal failure to the bladder unable to apply pressure to the system without the pump running (no air retention in the bladder) with the short cycling of the pump it could be a combination of failed bladder and hole in the steel casing of the pressure tank.  One common issue we find regularly in this area is the pitless fails where the PVC or other type of piping passes through the casing of the well through to the down pipe via electrolysis burns a hole in the pipe and causes the short cycling of the pump as a leak, which could also give the symptoms of the low pressure until pump engages as usually there is not a check valve between the well head and pressure tank on most systems I have encountered.  Short cycling a submerged pump is the worst on wear and tear on the impellers and pump, running continuously is a lot less harsh then short cycling for sure. Not knowing your exact situation of well setup may prove I just shot into the dark, just we do deal with a lot of well issues in our area and the most common effects or reasoning behind them being my post herein, whatever your situation, best of luck in an expedient resolve, water issues are at the top of the list of annoyances for sure.  The pig roast looked to be a blast, time constraints left us out, we are hoping to change that in our lifestyle and hope they are still ongoing when we do figure that all out.  Hope your water issues are short lived and an easy resolve.  Mike
Offline Nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« Reply #169 on: August 08, 2019, 06:22:10 AM »
     I'm late, but would also like to say thanks for a great time again!  Jeff, you DO know how to throw a party! 8)
WoodMizer LT50HDD51-WR
Lucas DSM
Offline GAB
« Reply #170 on: August 08, 2019, 07:54:59 PM »
We got home this afternoon.
Our trip was only 2350 miles.
Hope to be back next year.
GAB
W-M LT40HDD34 w/6' ext & SLR, JD 420, JD 950w/loader and Woods backhoe, V3507 Fransguard winch, Cordwood Saw, 18' flat bed trailer, and other toys.
Offline trapper
« Reply #171 on: August 09, 2019, 09:50:23 AM »
Jeff next years pigroast will it be july 31 and august 1?  I want to confirm my motel reservation now while rooms are still available at lakeside.  they are always booked up that weekend.
stihl ms241cm ms261cm  echo 310 400 suzuki  log arch made by stepson several Logrite tools woodmizer LT30
Offline Jeff
  • Fearless Leader
« Reply #172 on: August 09, 2019, 09:53:10 AM »
If assuming there is another, that is when it will be. Always the first saturday of august. That will also be Tammy and my 40th wedding anniversary.
Offline fat olde elf
  • Growing old is not for sissies - Betty Davis
« Reply #173 on: August 10, 2019, 01:19:58 AM »
A week ago right now a dignified group of sawyers finally called it a day including Jeff, Chet, WDH, Stan from Coldwater,Fat Old Elf and 4 or 5 others. What a load of talent in one spot. I had no idea that WDH was an accomplished bass player.
Quite a few first timers this year and that is encouraging for the future. So many people get my personal and profound thanks for a great time.  Glad to see Glassman to add to the list of "man" members including Pig Man, Cedarman (3 generations)
and Magic Man who is touring with his wife Pat in Alaska. Also glad to meet so many new ladies supporting their spouses addiction to making sawdust. Dr. William Glasser wrote a great book about us "Positive Addictions" He wrote an earlier book
"Reality Therapy" which I admire.
I put over 1700 miles on my Tacoma Toy truck with no problems except the gas prices in Michigan, Ohio, and West Virginia.
No reason to whine as my sainted wife Bonnie paid for the gas and 5 nights in 4 star motels. She says that's a small price to pay for 6 days and 5 nights of peace and solitude after 58 YEARS of marriage. Good girl.
Thanks again for my huge first aid kit. Bonnie also says thanks as she always patches me up. I got beat out by the nice young man that won the Stihl blower Great stuff ! Looking forward to next year.  My 65th high school reunion is next year. Only 28 of 48 of us left but I will lobby to have the reunion on the first SUNDAY in August 2020.  Keep the Faith..
Cook's MP-32 saw, MF-35, Several Husky Saws, Too Many Woodworking Tools, 4 PU's, Kind Wife.
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
« Reply #174 on: August 12, 2019, 05:07:41 PM »
Missed the gang but my 60th forestry school reunion was great.
Will plan to attend next yr if there is one.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
241 acres of woodland
Official 2018 15th annual PiGROAST RSVP topic.
Last post September 26, 2018, 05:49:08 PM
by olcowhand
2019 annual pigroast countdown topic
Last post May 27, 2019, 09:18:18 PM
by Dan_Shade
Official 2017 Pigroast RSVP 14th annual
Last post August 13, 2017, 11:59:13 AM
by Kingcha
Official 2016 Pigroast RSVP topic
Last post August 16, 2016, 06:30:51 AM
by Peter Drouin
