Author Topic: Power Feed, Woodmizer. Added to my mill.  (Read 662 times)
Offline Bill Gaiche
  • Home built bandsaw, Kioti ck30. Sthil 211 & 361.
« on: June 05, 2019, 05:06:45 PM »
Offline KenMac
  • I'm new, but don't feel so new!
Re: Power Feed, Woodmizer. Added to my mill.
« Reply #1 on: June 05, 2019, 07:32:28 PM »
Looks neat! I'm sure you will enjoy the upgrade.
Cook's AC3667t, Cat Claw sharpener, Dual tooth setter, and Band Roller, Kubota B26 TLB
Offline bags
  • Location: Up high in the Colorado Rockies, Westcliffe ,CO.
« Reply #2 on: June 05, 2019, 08:27:39 PM »
Your gonna like the power feed. I installed one on my mill and wouldn't do without it now--- pretty much the same setup as you have. I started with a rope but it stretched out after a while and I had to keep mess'in with it. I installed a cable and a strong spring at one end to keep tension, and it works fine now.
Offline bags
« Reply #3 on: June 05, 2019, 08:33:37 PM »
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: June 05, 2019, 09:57:36 PM »
That is a terrific mod Bill and bags.  8)
Offline Marche932
« Reply #5 on: June 07, 2019, 11:54:49 AM »
that is a good addition.  What power in watts is the 12V electric motor?
I have a home-made sawmill!
Offline ljohnsaw
« Reply #6 on: June 07, 2019, 12:17:42 PM »
To all of you guys, how happy are you with it being powered on just one side?  I'm contemplating but was thinking I need to power both sides.  I noticed that all three are on the powered/sawdust side.  Is that just because its a little heavier with the motor more on that side?
John Sawicky
Offline bags
« Reply #7 on: June 07, 2019, 08:29:46 PM »
Power on one side is all I need. Without the PF ya push a manual on one side anyway--- kinda like ride'in a horse with only one spur--- ya stick'em on one side, and the other comes along for the ride. All my factory/custom controls are on the right side of the mill, so theres room on the left side to mount the motor and cable. The engine (HP) on my mill will only cut so fast through a log, so two motors push'in the mill head would probably just shorten battery life through the day.
Offline randy d
« Reply #8 on: June 07, 2019, 09:04:59 PM »
I have had two LT15 with the hand crank I now have a LT28 with the power feed wo what a difference that can make better cuts because of the consistent feed rate and its just easier to do a lot more sawing in a day. I like it. Randy
Offline Bill Gaiche
« Reply #9 on: June 07, 2019, 10:00:51 PM »
I don't know. You might find out by looking it up on Wood Mizer web site. It is 12V. bg
Offline Bill Gaiche
« Reply #10 on: June 07, 2019, 10:08:24 PM »
I installed mine this way because of clockwise forward rotation of the gearbox. Also I wanted the rope across from me and out of the way where logs are loaded and lumber removed. It may be wired opposite of what mine is to make it turn counter clockwise. But it is mounted on the sawdust chute side . bg
Offline bandmiller2
« Reply #11 on: June 09, 2019, 07:10:32 AM »
One side drive is all that's needed unless you do a lot of dragback. You also want the cable to slip if something gets in the way or binds. You want just enough power to move freely through a cut. I feed my mill with a hydraulic motor and wire cable. Frank C.
Added power feed to Norwood Lumbermate (pictures)
Started by Slingshot on Sawmills and Milling
Last post February 23, 2011, 07:35:32 AM
by bandmiller2
WoodMizer Power Feed Upgrade
Started by mhasel on Sawmills and Milling
Last post February 10, 2005, 09:06:09 PM
by mhasel
Rope based power feed (Woodmizer)
Started by Woodslabs on Sawmills and Milling
Last post May 24, 2015, 12:37:55 PM
by AnthonyW
Woodmizer Power Feed Lessons Learned
Started by JoeyLowe on Sawmills and Milling
Last post June 10, 2003, 05:01:34 AM
by Bibbyman
