Author Topic: Fork grapple  (Read 784 times)
Online Bruno of NH
Fork grapple
« on: June 07, 2019, 12:18:05 PM »
Sold my Ingland log grapple and got this Stout fork grapple.
It saves me time from switching back and forth.
I like it so far.
Riehl Steel edger,Mahindra 3540 cab tractor loader F350 4x4 dump and lot of contracting tools
Online stavebuyer
Re: Fork grapple
« Reply #1 on: June 07, 2019, 02:43:22 PM »
Is it made to slip onto an existing set of pallet forks? I think you will love it. Quick attach is meaningless if you have to fight swapping hoses and the forks give you a little more log capacity as they are generally longer than the SS log grapples
Online Bruno of NH
Re: Fork grapple
« Reply #2 on: June 07, 2019, 02:56:01 PM »
Yes it slips on to the forks
I can move sawn lumber then pick up logs without changing attachments
Offline hacknchop
Re: Fork grapple
« Reply #3 on: June 07, 2019, 03:17:35 PM »
Good for you Bruno you deserve it .
Often wrong never indoubt
Offline LeeB
Re: Fork grapple
« Reply #4 on: June 08, 2019, 10:53:48 AM »
Interesting. I've been thinking about getting a grapple mostly for bush but this would I think be a better alternative and more useful. Did you get it local or order it?
Online Bruno of NH
Re: Fork grapple
« Reply #5 on: June 08, 2019, 01:47:00 PM »
I ordered it
It was $660 + $145 shipped to my door.
It's made by Smith Equipment in the USA
Offline Brad_bb
Re: Fork grapple
« Reply #6 on: June 08, 2019, 02:29:03 PM »
Does something besides the hose keep it from slipping forward on the forks?  I assume you have this on an FEL?  I know that visibility is an issue with forks on a skid steer, especially the higher the headache rack on the fork attachment.
It does look like a compromise.  Using forks is more difficult to pick up logs than just a grapple.  But forks are important for everything else.  It looks like when fully open the grapple could be in the way for picking up pallets of stickered lumber (depending on how high the lumber is stacked) and pallets that have stuff high enough to interfere.  I just use a rough terrain forklift and get by ok.  You may have to fiddle a little more picking logs up, but for me everything else has outweighed that.
Online Bruno of NH
Re: Fork grapple
« Reply #7 on: June 08, 2019, 04:55:35 PM »
Two bolts go in holes behind the forks and keep it on the carrier.
For my lumber stacks it's not in the way when opened all the way up.
If I stacked it any higher than that it would limit my lift capacity.
Offline sawmilllawyer
  • Ride hard, die free.
Re: Fork grapple
« Reply #8 on: June 08, 2019, 10:16:15 PM »
 8) Good on you Bruno! Now your cooking with gas. (old saying). Looks like a realy useful piece of equipment.
Stihl MS-361, MS-460 mag, Poulan 2150, 2375 Wildthing.
Offline LeeB
Re: Fork grapple
« Reply #9 on: June 08, 2019, 10:44:31 PM »
I ordered it
Thanks Bruno. It took me a while to find them last night. I thought they might be the makers. Most of what I saw were used ones at auction houses.
Who sells a one-handed, small log / firewood grapple? Tongs with a grapple
Started by Jasperfield on Forestry and Logging
Last post August 28, 2008, 09:12:16 PM
by Dave Shepard
sad
Bent Fork
Started by Bro. Noble on Sawmills and Milling
Last post September 01, 2004, 05:01:01 PM
by Jason_WI
Grapple bucket or grapple forks?
Started by alan gage on Sawmills and Milling
Last post January 30, 2019, 04:31:15 PM
by alan gage
3 point fork lift??
Started by opticsguy on Sawmills and Milling
Last post January 03, 2013, 07:52:08 PM
by ROUGH CUT
