Author Topic: Lazer  (Read 1056 times)
Offline Bruno of NH
Lazer
« on: June 07, 2019, 06:22:43 PM »
Has anyone added a laser on their edger?
I want one for the fixed blade
Thanks Bruno
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline Ron Wenrich
Re: Lazer
« Reply #1 on: June 08, 2019, 05:54:09 AM »
On the circle mill, we had fixed lasers for the headsaw which showed your saw line.  It was attached to the trusses overhead and shooting back onto the carriage.  You could do the same where it is behind the edger, so it isn't shining in your eyes.
I don't know about the new ones, but those older ones washed out in sunlight pretty quick.  We had our carriage end pretty dark and it was still a challenge to see it.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Lazer
« Reply #2 on: June 08, 2019, 07:44:35 AM »
I have two types of "edgers", a Baker twin blade, two laser edger and also a straight line rip saw with a laser.  I love the lasers.
I had Baker to custom build my edger, and along with other things, they put on two lasers, and tried to set it up as a twin blade SLR for me to edge green and KD wood.  Twin lasers may seem like overkill but with a laser on the fixed blade, I almost never use the right fence because its too easy to use the laser to set and sight down both edges.
Since I use the Baker to edge as much KD wood as green, most KD boards will have curve, and the fence won't work anyway.  Also, any over cut is money into the dumpster, so its important for me to be able to line up and shave edges like using my SLR instead of hogging off just the bark.  The lasers will let me do that.
My SLR has a red laser, the Baker has two green, and we use them under cover of a roof, and no sunlight, otherwise they wash out.
HobbyHardwoodAlabama.com
Offline Bruno of NH
Re: Lazer
« Reply #3 on: June 08, 2019, 08:56:38 AM »
I was looking at some green ones
My edger is under cover
Where would I look to buy one?
Offline doc henderson
Re: Lazer
« Reply #4 on: June 08, 2019, 09:04:57 AM »
I got mine off amazon, about 30 bucks.  It was 5 v but came with a power transformer to 110 volts so I used an inverter from 12v to 110 off the mill battery.  so the key is also finding a way to power it. it was green and I got the highest power mA.  I think it would run off a computer cord/car adapter as well so could go from 12 to 5 v directly.
Offline Bruno of NH
Re: Lazer
« Reply #5 on: June 08, 2019, 09:16:56 AM »
Doc
Did it come with mounting hardware?
Re: Lazer
« Reply #6 on: June 08, 2019, 10:18:57 AM »
yes, It has a round base with screw holes and a couple wing nuts for adjustment.  I used HD gorilla double sided tape to mount it, and my mill is outside so I bring it in when not in use.  I will try to add a pic if you like, but I am OOT today.
Re: Lazer
« Reply #7 on: June 08, 2019, 10:31:03 AM »
If you search green laser you can see a pic of it mounted on my sawmill and other info from others.  I know I could have pain more, and I could have pain less.  I have good shade and can see it well.  You will have to see what works best for your application.  I use it so I can see when the blade is about to enter the wood and know when to stop when pulling back, behind the cant.  I will forward you more info when I get home, maybe it was not Amazon,
Re: Lazer
« Reply #8 on: June 08, 2019, 10:40:34 AM »
I found a past pm and I said 20 bucks from amazon.  It was a 50 mW green line laser.  The person who I got info recommended apinex brand.  they were 150$,  hope that helps.
Offline Bruno of NH
Re: Lazer
« Reply #9 on: June 08, 2019, 10:42:09 AM »
Doc
Offline PAmizerman
  • Just Another Day In Paradise!!
    • Byrne Millwork
Re: Lazer
« Reply #10 on: June 10, 2019, 11:19:52 PM »
@Bruno of NH how's the edger working out for you? I am thinking about getting a Riehl with electric motor next year.
I want to be able to add a kicker to it like Peter's. Does the Riehl push the board out far enough that it can be pushed off the outfeed table without catching on the frame? Thanks
Hydraulics everywhere
Woodmizer edger 26hp cat diesel
Traverse 6035 telehandler
Case 95xt skidloader
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
Offline Bruno of NH
Re: Lazer
« Reply #11 on: June 11, 2019, 04:59:56 AM »
The edger is working great
It's well built
It saves lots of work
Offline PAmizerman
    • Byrne Millwork
Re: Lazer
« Reply #12 on: June 11, 2019, 07:57:30 PM »
@Bruno of NH does the board come out of the machine far enough on its own that a kicker could be added?
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
Offline Bruno of NH
Re: Lazer
« Reply #13 on: June 11, 2019, 08:03:15 PM »
Yes it does
Offline PAmizerman
    • Byrne Millwork
Re: Lazer
« Reply #14 on: June 11, 2019, 08:06:31 PM »
Awesome. I see a Riehl in my future!!
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
LAZER SIGHTS
Started by AtLast on Sawmills and Milling
Last post July 30, 2003, 08:37:58 PM
by BBTom
My friend just had the lazer eye surgery
Started by Pete J on General Board
Last post January 11, 2005, 04:07:36 PM
by FiremanEd
Anyone use/suggest the lazer for Wood Mizer mill?
Started by LaneC on Sawmills and Milling
Last post October 12, 2014, 06:03:40 AM
by ellmoe
