Author Topic: Lt 15 modifications  (Read 274 times)
Offline dbmoran
Lt 15 modifications
« on: June 07, 2019, 06:54:40 PM »
Making  changes to the lt15  as problems pop up
Stainless Steel bed rails
When a cant hook is just not enough on a manual mill
Reverse roll quarter sawing on a manual mill
Offline busenitzcww
Re: Lt 15 modifications
« Reply #1 on: June 07, 2019, 07:55:55 PM »
How does the hydraulic stay put? Im getting ready to try some rrqs and trying to figure out how to shift the log easily.
Offline dbmoran
« Reply #2 on: June 07, 2019, 08:28:02 PM »
I use the hook part from a cant hook adapted to a chain.
Wrap the chain around the log and at the top of the hydraulic cylinder
I welded a grab hook to hook the chain to.
Pump the cylinder up, which turns the log against the back stops.
If you need to go more set the dogs, let the cylinder down and catch another chain link
and pump the cylinder to roll more.
modifications
Started by gary courtney on Chainsaws
Last post January 16, 2014, 05:27:20 PM
by Andyshine77
Belsaw modifications
Started by apm on Sawmills and Milling
Last post May 10, 2018, 09:04:47 PM
by Flyingpig
Stihl 660 Modifications
Started by KiwiTimber on Chainsaws
Last post August 23, 2012, 12:52:07 PM
by lumberjack48
CSM modifications successfull!
Started by mad murdock on Sawmills and Milling
Last post November 25, 2012, 07:52:14 AM
by piller
