Author Topic: Don't try this at home!!  (Read 875 times)
Offline PAmizerman
  • Just Another Day In Paradise!!
« on: June 07, 2019, 10:25:42 PM »
I've been happy with this strapping. It's pretty tough stuff ;D
Hydraulics everywhere
Traverse 6035 telehandler
WM bms250 sharpener
WM bmt250 setter
Offline ljohnsaw
Re: Don't try this at home!!
« Reply #1 on: June 07, 2019, 11:33:13 PM »
 :o
Impressive.  What kind is it?  Did it stay stretched?
John Sawicky
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #2 on: June 08, 2019, 05:53:53 AM »
Why not go under the thing with the forks? Someone is going to get hurt doing that.
A&P saw Mill LLC.
License NH softwood grader.
Offline ladylake
« Reply #3 on: June 08, 2019, 08:05:32 AM »
As Pete said.  Steve
Offline PAmizerman
« Reply #4 on: June 09, 2019, 08:21:57 PM »
@Peter Drouin @ladylake this bundle was between a pile of logs and other slabs. I could not get under it with the forks. It was one of two bundles that we're seasoned. I needed it to put in my slab rack to cut for camp firewood. The machine tires never moved just the boom. I would NEVER even think about trying to load a customer like that. No one else was around. Once I got it lifted past the logs I set it down and went under it with the forks.
It was back in this hole.
Then moved to the cutting rack
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
« Reply #5 on: June 09, 2019, 08:25:28 PM »
@ljohnsaw I use 3/4" woven strapping with a 2500 lb break strength. I buy it from a company called
strapping products.com
It didn't stretch really the slabs just rolled up. Once I set it down the straps were not loose.
WM bms250 sharpener
WM bmt250 setter
    • A&P Saw mill LLC
« Reply #6 on: June 10, 2019, 01:58:20 PM »
 smiley_thumbsup
A&P saw Mill LLC.
