Author Topic: Hot rod  (Read 5012 times)
Offline sawguy21
Re: Hot rod
« Reply #80 on: July 10, 2019, 07:48:10 PM »
Every time somebody mentions pouring concrete my back starts to hurt. :D That is hard work! That is one sweet Ford pickup 8)
Offline thecfarm
Re: Hot rod
« Reply #81 on: July 10, 2019, 09:25:40 PM »
And another sickness has been taken upon. ;D
Offline Peter Drouin
    • A&P Saw mill LLC
Re: Hot rod
« Reply #82 on: July 10, 2019, 09:38:07 PM »
 smiley_thumbsup smiley_wavy, Hi, cfarm hows things up there north of me?
A&P saw Mill LLC.
License NH softwood grader.
Offline thecfarm
Re: Hot rod
« Reply #83 on: July 11, 2019, 05:04:01 AM »
Lonely. I need some company. Like someone with a Hotrod to keep me company. ;D
Offline crowhill
Re: Hot rod
« Reply #84 on: July 12, 2019, 08:07:33 AM »
For you Ford guys that want a bit more speed go to   Racing Junk Find “Silent Thunder” T-Bird  on Google. Friend of mine built this little Thunderbird up which did ok on the drag strip.
TimberKing B-20, Kubota M-4900 w/FEL with tooth bar, hyd thumb and forks, Farmi winch, 4 chain saws.
    • A&P Saw mill LLC
Re: Hot rod
« Reply #85 on: July 14, 2019, 08:12:01 PM »
All morning, but I got the 1968 Impala off the lift, Took it all apart and now it's home. [the lift]
I did try to buy the ss but he wanted too much for it.
Just a little more work and the 10,000 lb lift will pick up an 1800 lb Hot Rod just find.  :D :D :D 8) 8) 8) 8)
Happy days,
A&P saw Mill LLC.
Offline btulloh
Re: Hot rod
« Reply #86 on: July 14, 2019, 08:17:11 PM »
Sweet. That’s gonna be mighty handy.
HM126
Offline Bruno of NH
Re: Hot rod
« Reply #87 on: July 15, 2019, 05:43:15 AM »
Looks good Sir
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,Mahindra 3540 cab tractor loader F350 4x4 dump and lot of contracting tools
Offline Southside
Re: Hot rod
« Reply #88 on: July 15, 2019, 07:59:27 AM »
Sure would be a lot easier to clean out from under a mill if you could lift it in the air... :D
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
Re: Hot rod
« Reply #89 on: July 15, 2019, 09:55:15 AM »
I'm extremely jealous.
    • A&P Saw mill LLC
Re: Hot rod
« Reply #90 on: July 15, 2019, 07:01:36 PM »
I been jealous of that new barn you just put up too, With heat lights, a kitchen a fridge, stove.
:D :D ;)
  But now It will need a roof, Wonder where I can get some lumber? ;D
A&P saw Mill LLC.
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
Re: Hot rod
« Reply #91 on: July 16, 2019, 10:23:01 AM »
:D :D ;)
I think there is a sawmill near by you. I can get you his number if you need it. :D
    • A&P Saw mill LLC
Re: Hot rod
« Reply #92 on: July 20, 2019, 12:56:56 PM »
8) 8) dancing-jack usflag smiley_fiddler smiley_thumbsup
A&P saw Mill LLC.
Offline thecfarm
Re: Hot rod
« Reply #93 on: July 20, 2019, 01:04:34 PM »
Looks good.
I would be using that for my tractors.  ;D
Offline Jeff
  • Fearless Leader
Re: Hot rod
« Reply #94 on: July 20, 2019, 03:25:03 PM »
To quote an extremely close acquaintance.  :D :D
Offline Bruno of NH
Re: Hot rod
« Reply #95 on: July 20, 2019, 03:43:57 PM »
 8)
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Hot rod
« Reply #96 on: July 20, 2019, 09:02:38 PM »
Looks like a good anti theft device,  too. :D
Offline Jeff
  • Fearless Leader
Re: Hot rod
« Reply #97 on: July 20, 2019, 09:26:37 PM »
Winter storage! Should be just above the snow.
    • A&P Saw mill LLC
Re: Hot rod
« Reply #98 on: July 20, 2019, 11:06:27 PM »
There's going to be another bay on the right side of the lift facing the back of the hot rod. I want to free up the lift for my trucks to be worked on.
I'm going to have big windows to let a lot of sunlight in.
A steel bench bolted to the cement floor with a vice on it.
Then I can set up my wire feed welder air tools and torches at the lift bay.
Lumber sales are down from last year. can't sell wood might as well set up a nice garage.
I have a ton of band mills around me now selling lumber at all most what I pay for logs. I know they won't last long, but, It hurts me. have 3 or 4 guys going around on the road sawing too now. Years ago it was just me. And everybody has a small WM in there back yard now. Ross in Maine is doing a good job selling them.
I think it's time to find something else to do. Will see.
Too much work without Ann.
A&P saw Mill LLC.
Offline sawguy21
Re: Hot rod
« Reply #99 on: July 20, 2019, 11:39:05 PM »
I understand how you feel. :( That is going to be a great shop to play er work on your new toy.
