Author Topic: Old Corley Edger Project  (Read 656 times)
Offline Pepe_Silvia
« on: June 12, 2019, 03:37:11 PM »
Posted on the sawmill forum about this thing a while back and have come to the conclusion that the restoration project is not for me.
Bones seem to be pretty solid.  As best as I can tell everything that's supposed to turn or move (feed rollers, blade collars, blade shaft) turns or moves.  There are quite a few repairs done on it, and a few more repairs that will need to be done.
I contacted Corley and they gave me a couple pieces of literature on a similar model (Steel Weld), though it doesn't seem the be the exact one.
I'll answer any questions or inquiries to the best of my ability.
I have read, understand, and agree to the terms of posting an ad on the Forestry Forum.
Offline jimparamedic
Re: Old Corley Edger Project
« Reply #1 on: June 17, 2019, 09:46:15 AM »
Sure wish you were about 8hrs closer. Looks like it would be a good project
Offline Southside
« Reply #2 on: June 17, 2019, 10:04:50 AM »
Where is your spirit of adventure?  Half the fun is getting there!!!  :D
Offline Woodpecker52
« Reply #3 on: June 17, 2019, 10:43:59 AM »
Tough as nails when you get it going, bones look all there just get the steel wool out and start using elbow grease.  Lack flat belts on the right and a motor and v belts on the left and teeth. Had one just like it years ago ran it off a small Detroit diesel worked great but had a wood frame. I think it had some kick back links hanging down boards went in but not back.  I also used a counter weight to lift the front head if boards did not want to feed etc.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
corley edger
Started by sandsawmill14 on Sawmills and Milling
Last post August 27, 2015, 03:28:17 PM
by sandsawmill14
Corley edger ???
Started by lawnsbylane on Sawmills and Milling
Last post June 08, 2015, 08:27:58 PM
by lawnsbylane
corley edger
Started by egel on Sawmills and Milling
Last post October 21, 2012, 11:32:13 PM
by Ron Wenrich
Corley 60-NS-009 edger
Started by ArkansasRick on Sawmills and Milling
Last post September 18, 2018, 09:28:24 PM
by JB Griffin
