Author Topic: 050 mizer blades  (Read 489 times)
Offline csawrun
050 mizer blades
« on: June 12, 2019, 11:13:48 PM »
anybody else out there having problems with their .050 double hard blades flex life? last few boxes I've only been getting  3 sharpenings and last box i had two blades that still retained a curve when they broke. that is they wouldn't lay flat.
Offline ladylake
Re: 050 mizer blades
« Reply #1 on: June 13, 2019, 09:55:50 PM »
 .50 is not going to last as long as .42.  Would be  if some running .50 would report on their blade life.  Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #2 on: June 14, 2019, 05:55:04 AM »
I run .55  and get 5 or 6 + sharpening. In fact, I sharpen till the hard on the tip is gone.
then save them to cut nail wood.
I tighten the blade till I can't turn it anymore.
A&P saw Mill LLC.
License NH softwood grader.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: June 14, 2019, 09:18:56 AM »
How many sharpenings you get out of a blade is not a legitimate gauge without knowing how dull you allow them to get.  The more dull the less life.  Also as has been mentioned, thickness affects blade life.
Offline Southside
« Reply #4 on: June 14, 2019, 11:19:41 AM »
You also have to consider how blade performance impacts your production and lumber quality as part of the total cost equation.  If you are getting more deflection (due to band thickness not blade sharpness) or sawing slower due to conditions and band thickness is the limiting factor then do the additional sharpenings really pay off financially?
Offline csawrun
« Reply #5 on: June 24, 2019, 06:02:28 PM »
i run my blades for about an hour machine time i don't let em get dull, and i'm used to getting 7 or 8 sharpenings. i replaced the idle wheel just this week it was slightly out of true. maybe that's it, we will see
Wood-Mizer blades
Started by Hi-Country Orange on For Sale
Last post November 28, 2008, 08:47:16 PM
Wood-Mizer Resharp and non WM blades?
Started by Magicman on Sawmills and Milling
Last post September 23, 2017, 09:50:00 PM
by Magicman
Wood-Mizer's new Turbo 7 blades.
Started by Dave Shepard on Sawmills and Milling
Last post June 30, 2015, 06:53:22 PM
by bkaimwood
Band Blades & Wood-Mizer Resharp
Started by DR_Buck on Sawmills and Milling
Last post January 07, 2005, 08:51:27 PM
by pigman
