Author Topic: Deutz mdl. 2011 built 2007 trouble  (Read 363 times)
Offline moodnacreek
  • Sawin by the notches
« on: July 09, 2019, 12:21:43 PM »
How can I cheat the 12v fuel shut off so that it is always on ? This engine has a mechanical fuel stop lever that is not normally used. I have tried both hotting and grounding the solenoid that has one terminal on it but engine will not fuel unless the electric system and touch pad is used. I can crank it no problem but I can not turn on the fuel. This electric system must be removed as it is not reliable running in fine sawdust. I don't care about the shut down or the gauges or the charging system as all of this stuff is extra baggage and nothing but trouble. Thanks in advance, Doug.
Offline mike_belben
  • Pulp Friction
Re: Deutz mdl. 2011 built 2007 trouble
« Reply #1 on: July 09, 2019, 01:14:01 PM »
A solenoid is just a wound coil that creates magnetism when current flows through it.  If one wire only then intuition says the case is grounded and the wire is 12v+ so youve done what needs doing.
Usually a shutoff is failsafe designed. Magnetically pulls in to run and spring pops it out to shut down.  Does this seem like the layout youve got?
Revelation 3:20
Offline moodnacreek
« Reply #2 on: July 09, 2019, 07:21:38 PM »
Yes but when I touch a hot wire to this it clicks but no way will it fuel unless I go through the deep sea touch pad that has about 20 wires going to 4 relays. That engine control does something to the injection system that I can not duplicate so far.   Good to hear from you Mike. Any Ideas on what I am not seeing?
Offline Oliver05262
« Reply #3 on: July 09, 2019, 09:05:57 PM »
Give the Deutz Boys a call. Holtry’s in Roxbury, PA. deutzboyz.com
"You can't do wrong by doing good"
It's OK to cry.
Offline mike_belben
  • Pulp Friction
« Reply #4 on: July 09, 2019, 09:08:21 PM »
Post a pic of this shutoff solenoid.  Click is the sound of a relay's internal copper wiper contact closing.. Or a plunger contact plunging.  If the solenoid is what i think it is then it should stroke.  If it aint, the puck may be rusted up in the bore.
I can see there being several electronic conditions for the controller to move the shutoff to fuel on position, but if its only one wire into the solenoid then it only takes one thing to energize it and thats a completed circuit.  Pull it off, ground the case with jumper and hit the hot lug.  Ifn it dont pull in and you cant ungum it, replace.
[Unless im totally off on what this piece looks like]
Revelation 3:20
Offline moodnacreek
« Reply #5 on: July 10, 2019, 12:29:29 PM »
Mike, this engine starts and runs fine when it is in the right mood. It is very touchy on starting and shutting down. It may run all day or 1 hour or refuse to do anything. I can jump the starter and inj. pump [rack] but it will not start while spinning over on the starter no matter what. However if the electronic controller decides to work it will start. This engine has only 50 hours since new[ not rebuilt] There is in my mind some control involved in allowing this engine to run that I can not see. I also never learned to do photos.
Offline moodnacreek
« Reply #6 on: July 10, 2019, 12:34:42 PM »
Oliver, called them this am. They are telling me what I thought all along that is that the jumping of the fuel rack allows the engine to fuel and cranking it should make it go. I am missing something here. Getting back to them this pm. Good to here from you also.
Offline mike_belben
  • Pulp Friction
« Reply #7 on: July 10, 2019, 12:40:20 PM »
Yeah im kinda guessing what we are looking at here which is marginal at best.  Is this a mechanical injection pump and nozzles or a hpop, common rail whizzbang electronic show?
Revelation 3:20
Offline moodnacreek
« Reply #8 on: July 10, 2019, 06:01:12 PM »
Now I find my mistake: what I called a fuel solenoid is a anroid? that pulls the rack open while the engine is cranking. Ahead of that is a square box that looks like a sensor but is a rubber seal/window where 2 wires go in to the inj. pump housing to shut or open the fuel supply. If I put 12v to it she will start when I jump the starter. Those Duetz boys called me back and pointed this out.   The only disappointment is that I cannot remove this internal control to eliminate electrical problems to come.  Thanks to F.F. members and the Duetz boys for coming to my rescue.
Deutz Engine
Started by Greenskeeper on Wanted
Last post July 27, 2009, 05:35:59 PM
by LeeB
deutz motor
Started by treefarmer87 on Forestry and Logging
Last post February 22, 2010, 04:02:33 PM
by mad murdock
question
Timberjack with a Deutz?
Started by dgdrls on Forestry and Logging
Last post December 31, 2014, 11:32:21 PM
by Maine logger88
deutz injector
Started by allend on General Board
Last post July 17, 2015, 01:46:54 AM
by allend
