Author Topic: Tree question  (Read 390 times)
Offline Mike14
Tree question
« on: June 23, 2019, 03:55:07 PM »
I've got a pine that's split in two in an unusual manner.The right (wonky) side looks way more healthy than the taller main trunk. I'm wondering if I should cut the less healthy looking part off. Or what steps should be taken to make this tree thrive. I appreciate any feedback
Offline jimparamedic
Re: Tree question
« Reply #1 on: June 23, 2019, 04:10:37 PM »
Take it down. Not going to be a good tree to keep. It will tear up the fence when it gets big if left
Offline Mike14
Re: Tree question
« Reply #2 on: June 23, 2019, 04:20:25 PM »
It may be best to take down. I'm not sure. The fence is being moved back 20' later this summer
Online lxskllr
  • dummy with saw
Re: Tree question
« Reply #3 on: June 23, 2019, 05:00:50 PM »
I don't think that tree will ever thrive, but it's kind of interesting to look at. The two options I'd choose from are leave it as-is, or cut the main leader even with the fuller part on the right. Whatever option you choose, you should be prepared for catastrophic failure, and be willing to lose whatever's in it's path. I'm not any kind of arborist, and I'm partial to imperfect trees, so you should take the above with a grain of salt.
Offline SwampDonkey
  • Large Tooth
Re: Tree question
« Reply #4 on: June 23, 2019, 05:29:27 PM »
Looks like balsam or Fraser fir. I would take it down. Probably half rotten in the main stem down at the bottom.
Move'n on.
Offline KEC
Re: Tree question
« Reply #5 on: July 07, 2019, 09:47:44 PM »
I'm thinking Swamp Donkey has cut enough trees that  his opinion should carry some weight. You look at a tree and try to imagine what it looks like inside, then cut it and see, and do that over and over and develop a good eye for these things.
Magnolia Tree Question for all you Tree Experts
Started by DR_Buck on Ask The Forester
Last post June 27, 2015, 08:34:15 PM
by brendonv
Tree Question
Started by Typhoon on Ask The Forester
Last post March 11, 2004, 11:38:28 PM
by crosscut
Ash Tree Question
Started by 123maxbars on Sawmills and Milling
Last post July 26, 2018, 11:44:22 PM
by MAF143
Another Tree ID Question
Started by Rickcnc on Tree, Plant and Wood I.D.
Last post June 26, 2016, 08:55:48 PM
by Ron Scott
