Tally-I/O
Author Topic: The most overlooked maintenance issue around the mill yard.  (Read 2420 times)
Online Southside
Re: The most overlooked maintenance issue around the mill yard.
« Reply #20 on: June 27, 2019, 10:27:10 PM »
The wasps have gotten fired up around here this week too. Become quite aggressive, another guy observed the same thing.
Offline DARRELL1972
« Reply #21 on: June 27, 2019, 11:49:11 PM »
Yellow jackets and wasp can't be tolerated around my mill. My brother is highly allergic so I keep them under control.
95lt40hd
74 8k windham forklift
2018 eg100
Offline caveman
  • In the land of the blind the one eyed man is king
« Reply #22 on: June 28, 2019, 10:01:06 AM »
For those times when you find yourself without wasp spray and when a flaming greasy rag on a stick would not be advisable (under the eave of your wooden house or around the mill), diluted Dawn dish soap will kill them but not as quickly as wasp spray.  Just think, a product that will clean oily ducks, kill stinging insects and serve its intended purpose.
Offline Nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« Reply #23 on: June 29, 2019, 06:24:45 AM »
     Dish soap stops them from flying and will eventually kill them, but it does not stop them from crawling and stinging before they die!  A friend of mine found that out the hard way.  Several of 'em got up his legs and stung him before he figured out he might want to leave the area. :D
WoodMizer LT50HDD51-WR
Lucas DSM
Online Bruno of NH
« Reply #24 on: June 29, 2019, 06:39:50 AM »
Clean up all the wood scraps and sawdust
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Online YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #25 on: June 29, 2019, 07:18:06 AM »
I'm NEVER without a few cans of wasp spray. :D :D :D
HobbyHardwoodAlabama.com
Offline CCCLLC
  • It's not to big, load it!
    • Carolina Custom Cut
« Reply #26 on: July 05, 2019, 07:50:15 AM »
A little late to the party but mine seems to be the contacts and springs on my older lt40 hd. Those 4 way valves are close in there and tough to do any preventive maintenance. So always trying to take notice of any "odd" feel in the handle.
Offline caveman
« Reply #27 on: July 09, 2019, 06:38:00 PM »
 I'm Not at the sawmill but at my parents' place in Franklin, NC today and a wasp nailed me in the neck. There were two nests and I did not have any spray. The soapy dishwater did them in.
Caveman
Online YellowHammer
« Reply #28 on: July 09, 2019, 08:13:24 PM »
They seem particularly mean this year.  We have been steadily killing nests.  The more we kill, the more pop up.  We had two people get stung last week.  Seems like every open hole drilled in the mill or roller tables is getting nested in.  They are nesting in the down tubes of our gates, and the door frames.
No mercy is given by either side.  This is the view from the controls.  A bottle of water and a can of wasp spray.
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #29 on: July 09, 2019, 09:26:20 PM »
I use spray adhesive for wasps. Spray them in flight and their wings stick together, and immediately fall to the ground. Flame throwers work good for the paper wasp nests, but not good around buildings. :D
Offline farmfromkansas
« Reply #30 on: July 09, 2019, 10:01:41 PM »
The coop is selling these sticky traps, similar to the ones you add water to, and I hung one up at the farm and it is collecting mud dobbers.  Didn't know of anything that worked on those, but the sticky traps do. The more noise they make, the more wasps come and get stuck.
Online WV Sawmiller
    • Green's Sawmill Services
« Reply #31 on: July 10, 2019, 03:25:46 PM »
   I was at the dentist office this morning and while waiting for my wife (A common occurrence) and I noticed a big red wasp investigating my power mirror on my truck apparently planning on setting up residence there.
Online Southside
« Reply #32 on: July 10, 2019, 04:04:22 PM »
Is it because of where you live that you have to go to the dentist so often?  :D  :D  :D  Sorry - you left the door wide open on that one!!   ;D
Online WV Sawmiller
« Reply #33 on: July 10, 2019, 06:19:17 PM »
SS,
 I think it is because I have a cracked tooth my dentist has been trying to pull for 2 years and I have refused and finally went for an implant consult today. Actually I do have my regular dentist appointment tomorrow then back Monday to get the bad tooth out and start the implant process.
   And yes I have heard the WV Toothbrush vs Teethbrush joke ever since I moved to WV.  ::)
Online Southside
« Reply #34 on: July 10, 2019, 11:48:43 PM »
WV-
On a more serious note I think a new member may have contacted you recently as he will be in your area coming up pretty soon, if you two get the chance to meet up I can tell you it will be time well spent.  He loves to fish as much as you do and has supplied me with a couple of really, really, good meals already.  Good luck with the tooth!!
Online WV Sawmiller
« Reply #35 on: July 11, 2019, 08:15:13 AM »
SS,
    I will be looking forward to the visit. I may only be eating grits and soft eggs at the time but we'll treat him the best we can. :(
An Overlooked Maintenance Item
Started by Magicman on Sawmills and Milling
Last post July 21, 2013, 12:46:16 PM
by Martha White Nelson
Mill maintenance.
Started by backwoods sawyer on Sawmills and Milling
Last post January 31, 2011, 05:54:49 PM
by Meadows Miller
Saw mill maintenance?
Started by WoodChucker on Sawmills and Milling
Last post July 22, 2003, 05:34:59 PM
by Kevin
Improvements and Maintenance to my mill
Started by VictorH on Sawmills and Milling
Last post June 07, 2014, 03:26:58 PM
by Magicman
