Author Topic: Will it work?  (Read 336 times)
Offline gmacky
Will it work?
« on: June 28, 2019, 04:54:18 PM »
I have an air compresser with a ten gallon tank, operating pressure 0-125 psi. Can I use a high tork impact gun with it?
Online btulloh
Re: Will it work?
« Reply #1 on: June 28, 2019, 05:02:07 PM »
Not really.  Not enough CFM.  You could probably get a short burst with a long recovery time.  Maybe that's good enough for what you need to do.
Impacts are rated at X CFM @ X psi.  Air compressors have the same ratings, usually at two different psi's.  The compressor needs to have the same or higher rating as the impact to deliver enough air for continuous operation.
Check out the ratings for your compressor and your impact.  You should be using a 3/8 or 1/2 hose for that volume of air also.
You can always try it and see.
HM126
Online doc henderson
Re: Will it work?
« Reply #2 on: June 28, 2019, 05:27:28 PM »
if you are rotating tires a few times a year it will work.  all day long and you will ruin the compressor.  if it is oiless, may have a limited duty cycle.  dewalt and others make a battery operated 1/2 inch as well. when I use my air a distance from my shop, I would use a reservoir such as a air bubble at the end of a long hose so it can accumulate volume and pressure near the point of use.  if you had a larger tank it would help but may not be matched to the compressor and over do the duty cycle.  HF sells a triple tap and I put this in my air bubble and have a double male fitting in, and then a hose out to add volume and provide more pressure at the tool instead of the drop across the long hose.
timberking B 2000, 277c track loader, PJ 32 foot gooseneck, 1976 F700 state dump truck, JD 850 tractor.
Re: Will it work?
« Reply #3 on: June 28, 2019, 06:08:01 PM »
is this a high end compressor?  with oil?  full duty cycle?  what is use going to be?
Offline Southside
Re: Will it work?
« Reply #4 on: June 28, 2019, 06:42:05 PM »
My Milwaukee 18V, 1/2" impact is rated for 1,400 ft lbs torque, I have absolutely no idea where my air impact is these days and I will not be looking for it either.
Online btulloh
Re: Will it work?
« Reply #5 on: June 28, 2019, 06:47:26 PM »
The good battery impacts are amazing.  And wonderful.  Air, shmair, get that hose outta here.
Didn't know there was one rated for 1400 ft/lbs.  I guess they are getting better every day.
HM126
Offline Southside
Re: Will it work?
« Reply #6 on: June 28, 2019, 07:18:47 PM »
It has a smart setting too that senses when the torque has broken loose and slows down the socket so you don't spin the nuts off at full speed and send them flying. I use it to adjust the outriggers on the 70 all the time, it's that sensitive and quiet to boot.
Offline gmacky
Re: Will it work?
« Reply #7 on: June 28, 2019, 07:30:07 PM »
Thanks for all of the info!
Online Bruno of NH
Re: Will it work?
« Reply #8 on: June 28, 2019, 08:34:07 PM »
I'd go cordless
They work super
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,Mahindra 3540 cab tractor loader F350 4x4 dump and lot of contracting tools
High work boot vs regular work boot
Started by bigtrees on General Board
Last post May 01, 2019, 04:29:03 PM
by Skip
question
Work
Started by Drake the sawyer on Sawmills and Milling
Last post November 30, 2015, 06:40:59 PM
by Grunex
will it work
Started by mooleycow on General Woodworking
Last post January 21, 2012, 10:27:27 AM
by terrifictimbersllc
Does this work for you.....
Started by Samh200 on Timber Framing/Log construction
Last post February 05, 2011, 11:46:50 AM
by Samh200
