Author Topic: Woodmizer LT35HD Setworks  (Read 436 times)
Offline WoodyMcSander
  • Woodturner with woodcutting powers.
« on: July 02, 2019, 05:32:05 PM »
In using setworks on my Woodmizer LT35HD, I have had some issues with the thickness of the boards I get from the settings I input.
Over the weekend, the goal was to cut 9/4 (2 " thick) slabs.  I set setworks to 2 5/16", but the boards were cutting at 2 1/16".
This has happened to me for a lot of stuff I cut.
Is this normal?  Do I need to double check my thicknesses every time or do I need to do a calibration on my machine in some manner?
Thanks in advance.
Jon
Offline ladylake
Re: Woodmizer LT35HD Setworks
« Reply #1 on: July 02, 2019, 05:56:20 PM »
 Stress in a log will make the ends thinner and the middle thicker.   Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline Southside
« Reply #2 on: July 02, 2019, 06:21:35 PM »
First thing I would do it check your actual drop.  With no log or cant on the bed set the head to a known height - say 16" to the back of the band (under tension), then drop the head  1 1/16" - 1 1/8", depending on the kerf of the band you are running, and measure to the same spot on the band.  If it helps use a sharpie to mark the band and bed so you know you are measuring at the same location each time.  If after four or five drops the tape is running true then you know the issue is not with the setworks.  It could be as ladylake said stress in the cant, it could be your outriggers are not set right.  Is your clamp creeping up on you causing the cant to shift?
If the tape is not running true then check the connection and wire to the encoder.   Past that you would need to call WM for diagnostics.  Good luck.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #3 on: July 02, 2019, 10:21:38 PM »
   You can do like Southside suggests only just lightly kiss the log on each cut to produce a 1/4" deep cut, back out, drop and repeat and measure. That will certainly show what you are staring with on your cut.
   Mine very consistently takes a 1/8" kerf so if I set it to 1-1/4 drops I will be cutting exactly 1-1/8" thick boards. I use my setworks religiously.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #4 on: July 02, 2019, 10:32:10 PM »
I agree, and Ive done it many times.  Make the end of the log into a ruler, and check it with a tape measure.  Or just measure the drops with a tape measure directly.
HobbyHardwoodAlabama.com
« Reply #5 on: July 05, 2019, 07:24:45 AM »
I need to clarify.
I get consistently thick boards.
What I'm not getting is a thickness that is consistent with what setworks is telling me.
If I set setworks to 1 1/16" I expect to get a 1" board.
In this case last weekend, I was setting to 2 5/16" to get a 2 1/4" board, but I was getting right at 2".
Somehow I lost a " somewhere.
Thanks for all the input.
Offline millwright
« Reply #6 on: July 05, 2019, 10:38:57 AM »
When I first got my 35, I had a lot of trouble with the brake on the up- down. It would overshoot when drooping down and always be thicker than it was set for. I replaced it a couple times with no success . When I added the debarked I upgraded to the much heavier duty right angle gearbox. It has been great ever since, set it 1/16 over for kerf and comes out right on every time.
Woodmizer LT35hd
Started by MReinemann on Sawmills and Milling
Last post September 05, 2012, 05:58:24 PM
by MReinemann
woodmizer LT40HD vs. LT35HD
Started by mjancius on Sawmills and Milling
Last post April 30, 2015, 12:29:40 PM
by isawlogs
Woodmizer LT35HD Pulley
Started by Rhodemont on Sawmills and Milling
Last post January 15, 2018, 03:24:05 PM
by millwright
setworks for my woodmizer
Started by DansSawmill on Sawmills and Milling
Last post July 28, 2006, 12:54:10 PM
by DansSawmill
