Author Topic: Jumper Cables - Good, heavy, reasonably priced?  (Read 1443 times)
Offline btulloh
« on: July 05, 2019, 12:53:46 PM »
I know that those three things don't go together, but let's see if there's a way to get some good ones that aren't $250.
My good pair (??) is letting me down and needs to be replaced.  The copper jaws turned out to be copper plated, which are now rust plated.  My bad pair is just, well . . . bad.  They were dedicated to a vehicle for very occasional use, but they're not adequate for tractors and such.
Of course I have a jump box, which is great for it's intended purpose, so we can skip that conversation.
Looking around today for replacements, I don't see anything that grabs me.  I'm thinking 2 ga. 20 ft is what I can get by with.  I see these ranging from $25 to $250.  Some look too cheesy.  $250 doesn't sound good to me.
Anybody happy with their jumper cables?
HM126
Online lxskllr
  • dummy with saw
Re: Jumper Cables - Good, heavy, reasonably priced?
« Reply #1 on: July 05, 2019, 01:23:15 PM »
I used to have some made from old welding cable. Not sure what happened to them, but they were the best I had. I think I might have found them in the trash. Don't know how one would get some without working for a welding shop.
Offline goose63
« Reply #2 on: July 05, 2019, 01:59:19 PM »
I have 2 sets made out of welding lead you can buy all the welding lead you want at a welding supply store
goose
thank you to all the vets
Online lxskllr
  • dummy with saw
« Reply #3 on: July 05, 2019, 02:03:26 PM »
LoL! A welding shop! Who'd have thought of that?! Not sure what was going on in my head. I guess I was thinking of getting some as cheap as mine were($0), but that's a tall order regardless of what cables you get.
Offline btulloh
« Reply #4 on: July 05, 2019, 02:17:37 PM »
Interesting turn.  I actually have a bunch of extra welding cable.  I also can put new clamps on my "good" cables.  Or both.
So now this comes down to a discussion about clamps.
I am also suffering from too much broke stuff, too many chores, and too many projects.  So there's that.  Recently I've had a number of one to two hour jobs turn into multi-hour jobs.  Like sorting out the cable problems on this tractor, that has become a building new jumper cable project.  ( I could start a whole thread on broke stuff that requires another broke thing to fix, that requires yet another broke thing . . .  But that would empty the room in a hurry.   :D )
Now I'm down to sourcing good clamps that will fit #00 wire AND connect to not only battery posts and cable ends, but a variety of things like solenoid posts, etc.  In many cases, at least at one end, there's no easy access or limited access to the battery itself.  Not to mention that normal alligator clamps don't like to connect to the new fangled terminations they're putting in vehicles now.
So anyway, I've looked at a variety of clamps online and nothing is jumping out as a good choice for #00 cable.  This can't be that difficult.
HM126
Online lxskllr
  • dummy with saw
« Reply #5 on: July 05, 2019, 02:50:53 PM »
How about something like this...
Amazon.com: Heavy Duty 1000A Battery Jumper Cable Clamp Clip Booster Lead Electrical 2pcs Red&Black: Automotive
Add your own terminal ends for attachment.
edit:
As far as that goes, scavenge clamps from dead cables, and bolt them on using your terminal ends.
Offline btulloh
« Reply #6 on: July 05, 2019, 03:34:19 PM »
Saw those, and a thousand others.  Connecting them to #00 can be challenging, especially without seeing them in person.
FWIW, I've terminated #00 (and even #2) without proper tools and it takes longer than you would think.  It's a project.
Ring terminals for #00 cost 5$ apiece, give or take.  So that's $40 for the clamps, $20 for the ring terminals (Which are probably too big to fit).  Time, aggravation, marginal results.  Hmmmm.  Scrounge clamps fromm my clamps that don't work?   Hmmmm . . .
I think there are some $60 cables out there that can be ok for a while, no assembly required. I'll quote a noted philosopher named  . . . . . . . . . "lxskllr" . . . . who recently said in another thread: "Tonight, I could throw out every dollar I have, and I'll have more tomorrow. It's virtually infinite. Time OTOH, is gone forever once it's gone. Every second I spend doing something I don't want to do comes off the ledger, never to be replaced. I'll take time over money every time."
So anyway, I appreciate the link and the thought, but I'm trying to live up to your credo!  :D :D
Offline btulloh
« Reply #7 on: July 05, 2019, 03:46:43 PM »
Y'all almost got me to go down the welding cable rabbit hole!!!   :o :o I must be getting weak in the brain!!   :( :(
When I posted this, I was thinking maybe someone would chime in with "I bought some XYZ cables recently at Unknown Auto Parts and they work pretty well".   :D :D
It's early yet, and hope springs eternal.  After dinner tonight, I'm expecting some good traffic on this topic!
HM126
Online lxskllr
  • dummy with saw
« Reply #8 on: July 05, 2019, 04:10:18 PM »
You definitely wouldn't have liked my alternate plan... Pulling parts off the old clamps, and building new ones out of wood  :^D
I take particular pleasure in making something out of nothing, and will spend more time than it's worth playing with trash just for the fun in doing it. I don't have the skills a lot of you have. I can't weld, I don't have metal working supplies, no fancy woodworking tools... What I can do is work miracles with a leatherman, Swiss Army knife, some tiewire, and assorted junk to pick through. It usually isn't pretty, but it generally works. Mostly...  :^D
Offline snobdds
Offline doc henderson
« Reply #10 on: July 05, 2019, 04:30:47 PM »
I have some for the kids, (rarely used) that were  2 g 20 feet for 29 bucks at a black Friday deal at a farm store.  for my truck I had fleet wireing installed so 25 feet with a connection on the front and back of the truck, wired via breaker to the electric system.  the cables have the mated connector so I can jump from 25 feet, front or back of the truck.  worth it since I usually so the jump starting at my house.  although My son is getting asked to do more for the experience.  the cheap ones have and insulation that looks a little cheesy, but the new ones do too.  I tried to buy welding cable but both leads were black and separate wires.  they said there was no such thing available like you see with cables.  would have gotten tangled ect.  If all that is wrong with the old set, is the clamps, I would buy new clamps.  I still have my first pair, but a few melted areas of insulation and clamps also rusted and a little abused.  with the fleet wire, I can jump my truck as well without raising the hood.  I will post pics later.
timberking B 2000, 277c track loader, PJ 32 foot gooseneck, 1976 F700 state dump truck, JD 850 tractor.
« Reply #11 on: July 05, 2019, 04:36:18 PM »
I see an Energizer brand called a permanent installation kit, 1 g, 30 feet.  the connections look like mine.  I had mine professionally installed and paid hundreds.  on amazon for 80 bucks
Offline snobdds
« Reply #12 on: July 05, 2019, 04:38:58 PM »
Mine are welding cables and they came separate as well.  I just took some gorilla tape and taped them togheter ever 12 inches to keep them together.
The ones I linked to are the ones I have and they are heavy, which to me means they are solid copper wire.
« Reply #13 on: July 05, 2019, 04:42:52 PM »
the outer cable (that unplugs and stores behind my back seat) was made from a set of cables, but the permanent truck wire front and back was done with welding cable.  if you wire the batteries to connections at either end of your vehicle, you sure do not want a short!
Offline rubberfish
« Reply #14 on: July 05, 2019, 06:44:55 PM »
The ones that snobdds linked are in Canuck Bucks so even cheaper with the current exchange rate.
Just buy some quality ones and be done with it. And don't ever loan them out. Tada done. smiley_beertoast
Confucius says "He who stands with hands in pocket is feeling cocky"
Bob
Offline sprucebunny
  • Gender: Female
« Reply #15 on: July 05, 2019, 06:55:55 PM »
I have some real nice ones that were reasonable priced but I don't remember where I got them and have never seen a brand name on any of them. They are blue. Does that help ???
Offline btulloh
« Reply #16 on: July 05, 2019, 07:07:40 PM »
They look good. In my Amazon app it shows $181.xx American US Actual Dollars. I keep waiting for the lower price to show up!!
Im trying to warm up to spending that much. I get it, you get what you pay for. I just paid real estate taxes, auto insurance, three new tractor batteries, an unscheduled $800 lawnmower repair, and couple things I cant even remember. Give me a few minutes to get my spending shoes on.  Oh yeah, I need a new set of 18 tires on the truck.
Maybe someones going to weigh in with almost good enough $60 cables.
HM126
Offline luvmexfood
« Reply #17 on: July 05, 2019, 07:14:02 PM »
I got a set at O'Reileys auto parts a few years back. #2 cable, long enough to go from truck battery to tongue of my trailer to supply power to the winch mounted on it. If I need the winch I just hook it up to power with them. One of these days I might get around to running wire permanently. They have the kind of insulation that doesn't get stiff in cold weather. Metal ends. I have used them a bunch and would buy again if needed. Can't remember what I paid but think in the forty dollar range.
Give me a new saw chain and I can find you a rock in a heartbeat.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #18 on: July 05, 2019, 07:25:15 PM »
OK, here are the $65.99 cables:  LINK
Offline rubberfish
« Reply #19 on: July 05, 2019, 08:00:44 PM »
The thread will be quiet for an hour or so while everyone jumps on that.
Very good price. Thanks for the link.  8)
Bob
What size jumper cables to carry?
Started by terrifictimbersllc on Sawmills and Milling
Last post May 29, 2011, 08:47:00 PM
by ljmathias
Is there a good reasonably priced small diesel engine?
Started by OneWithWood on Alternative methods and solutions
Last post May 03, 2007, 01:10:54 PM
by treebucker
066 magnum... time jumper???
Started by knuckledragger on Chainsaws
Last post May 21, 2019, 10:34:40 PM
by knuckledragger
smiley
Stump Jumper lost his typist!
Started by Mrs._Stump_Jumper on General Board
Last post June 18, 2004, 05:30:39 AM
by Patty
