Author Topic: gas tank  (Read 319 times)
Offline hopm
gas tank
« on: July 05, 2019, 10:05:52 PM »
Squirrels developed a taste for my gas tank on my mill. Anyone know where I might find a 9 quart fuel tank for a 16 hp vanguard?
Any response is appreciated!!!
Online btulloh
Re: gas tank
« Reply #1 on: July 05, 2019, 10:12:14 PM »
Had that problem once. It was a top corner so I tried patching with some kind of jbweld product. Still fine after several years.
I found some honda clone tanks on amazon that were affordable and worked well on another engine (it was a honda clone). Good value but would not mount on yours without mods.
HM126
Offline sawguy21
Re: gas tank
« Reply #2 on: July 05, 2019, 10:50:59 PM »
Check with a shop that sells lawn and garden equipment, they may have a used tractor tank.
Offline doc henderson
Re: gas tank
« Reply #3 on: July 06, 2019, 04:34:18 AM »
is it the one with a hole in the middle for the air filter?  that will be tough unless you want to remote mount something different.  I had them eat the corner off mine as well, but it was on my mill a cube one, my log splitter has a vanguard 18 hp.
timberking B 2000, 277c track loader, PJ 32 foot gooseneck, 1976 F700 state dump truck, JD 850 tractor.
Offline hopm
Re: gas tank
« Reply #4 on: July 06, 2019, 01:39:03 PM »
yes it is the one surrounding the air filter. I found one on line.....$259.....i have my patch kit ready to test this afternoon.  :laugh: :laugh:
Online btulloh
Re: gas tank
« Reply #5 on: July 06, 2019, 01:47:11 PM »
Patch worked for me and was far less than $259.  Seemed to keep the squirrels away too.
Bonne chance.
HM126
Offline hopm
Re: gas tank
« Reply #6 on: July 06, 2019, 05:51:45 PM »
I think the patch is going to be fine. I used aluminum flashing and plastic weld. The cap however, is a lost cause. Going to have to make an order.
Offline WV Sawmiller
    • Green's Sawmill Services
Re: gas tank
« Reply #7 on: July 06, 2019, 06:24:42 PM »
   Is this one similar to an outboard motor tank and hose system? If so you might check with you local boat motor dealer. Good luck.
Mix gas in saw tank?
Started by Sprucegum on Chainsaws
Last post June 03, 2006, 06:09:26 AM
by hondo
Gas in the tank
Started by Lnewman on Chainsaws
Last post May 11, 2013, 02:37:43 PM
by John Mc
Oil foaming in tank?
Started by RCBS on Chainsaws
Last post March 10, 2014, 08:38:06 PM
by clww
046 fuel tank
Started by golden foot on Wanted
Last post January 06, 2010, 11:33:12 AM
by golden foot
