Author Topic: Sawmill Shed Layout  (Read 3918 times)
Offline Bindian
  • Gender: Female
Re: Sawmill Shed Layout
« Reply #60 on: August 12, 2019, 12:59:03 AM »
I'm a little late to the party, but microsoft also makes a wireless adapter that plugs in to a TV that has HDMI (audio video out) and USB (power) connectors (about $50). You can turn your TV into and extended monitor from any compatible wireless device. I use mine to sit on the couch with my feet up watching sawmill videos on the TV (wirelessly connected to the laptop as a monitor) while reading about sawmills on my laptop screen.
The new 65 inch TV I bought has wireless on it.  Just gotta figure out the HDMI ports and how to switch it.  I have 3 sources with one being hooked to the satellite.  You tube is already on the TV, so I guess click that and see if it connects to an open HDMI port?
hugs,  Brandi
Mahindra 6520 4WD with loader/backhoe and a Caterpiller E70 Excavator.  My mill is a Woodmizer LT40HD Wide Diesel.
My Hero is Johnny Jett
Offline flyboy16101
« Reply #61 on: August 13, 2019, 03:09:55 PM »
I built this in a hurry just so my mill would not be left out in the weather and so I could so saw anytime that I got a chance (some how my day off work is always 100% chance of rain). I knew from start that it would be a little tight on space. I am drawing up plans for a 44x40 to replace this and also store some lumber and equipment (skid steer, maybe an edger) but the more I think about it I doubt I will have very much lumber storage due to equipment and being able to move around while I do things without moving machinery outside to make room to work. I would like to go 40x100 or bigger but I have to make a lot more flat ground to build on first.
Wood-mizer Lt35, International 504 w/ loader, Hough HA Payloader, Stihl Ms290, Ms660, Logrite Cant Hook
Offline Bindian
  • Gender: Female
« Reply #62 on: August 13, 2019, 06:06:39 PM »
Looks warm and cozy.  Can you run it with the doors closed?  Flyboy, is that mean you fly?
hugs, Brandi
Offline flyboy16101
« Reply #63 on: August 22, 2019, 08:44:47 AM »
I was going to put an exhaust in but didn't since I don't have room for the lumber inside so the doors are always open when I'm sawing. I fly some a flight engineer for the reserves but not very often anymore.
Offline Bindian
  • Gender: Female
« Reply #64 on: August 22, 2019, 03:51:11 PM »
Flyboy 16101,
     THANK YOU for your service.  I'm an aircraft mechanic with a major airline.  Been there 27 years.  Years ago, I thought about becoming a WOC in the Army to fly helicopters.  At that time I was rebuilding wrecked helicopters.
                                                hugs, Brandi
Offline jeepcj779
  • "Watch this" - Famous last words
« Reply #65 on: August 23, 2019, 02:46:39 AM »
If your TV is new, it is likely of the "smart" variety. That being the case, you can probably just use the TV remote to select youtube and watch it using just the TV.
Saw Shed Layout question
Started by Rob in NC on Sawmills and Milling
Last post February 13, 2018, 08:43:26 PM
by WV Sawmiller
Sawmill Layout
Started by woodmann on Sawmills and Milling
Last post May 18, 2010, 05:31:12 AM
by Ron Wenrich
Sawmill layout
Started by dewwood on Sawmills and Milling
Last post August 09, 2002, 10:13:36 PM
by C_Miller
Sawmill Layout
Started by Stephen1 on Sawmills and Milling
Last post November 17, 2011, 07:08:14 AM
by thecfarm
