Author Topic: Burl wood table id  (Read 252 times)
Offline Vanduve
Burl wood table id
« on: July 14, 2019, 08:03:39 PM »
3-4 pieces of burl coffee table base. I purchased it to go with a redwood slice we just finished but at home it doesn't match. I'd like to add a finish to bring some of the reds out but it helps to know what I'm working with!
Offline thecfarm
Re: Burl wood table id
« Reply #1 on: July 14, 2019, 09:16:47 PM »
Looking forward to see that finished off.
Get your location in your profile. That will help with the ID some. I suppose you bought that from a local guy?  Not something that could be from 1000 miles away? Overseas even?
Online btulloh
« Reply #2 on: July 14, 2019, 10:16:42 PM »
Red aniline dye would be the best bet. That and a similar finish as the the top. Id find a little place out of sight to test it. Nice piece.
HM126
Online btulloh
« Reply #3 on: July 15, 2019, 11:32:24 AM »
I think a little bit of red highlight will bring it around when it has the same sheen as the top.  What is the finish coat on the top?  Lacquer?  That would be my choice for the base.  A tone spray could be used to add some highlights just before a top coat.
Interesting piece.  Nice dog.
HM126
Offline Vanduve
« Reply #4 on: July 15, 2019, 12:28:42 PM »
I suppose overseas is a possibility. I am in  Southern California but I got from a non-English speaking Buddist on Craigslist.  He didn't know what wood it was, other than old and he had it for a long time. Specifically, his listing called it "junk" I still had to pay for it though!
Yes, that is what I hoping. Just in wiping with mineral spirits the red comes up. Due to the multi-facited surface of the base and the properties of epoxy, I'm not comfortable using the same finish as the top. Lacquer maybe the best option.
I will test it. I've been working (testing) on the underside just trying to get a feel of what I'm working with. The gold looking word is hard like pine and the red areas are soft like redwood and unless I am missing a joint, it appears to be on the same piece
Blue Gum Burl Double Slab Table - ORB Timbers, Australia
Started by HSV on Peterson Portable Sawmills
Last post October 18, 2016, 09:19:25 AM
by Dakota
ebay auction to support our forum. Redwood Root burl Table from Burlkraft
Started by Jeff on Current Auctions and Auction Archives
Last post May 30, 2006, 12:52:35 PM
by Paschale
cutting burl wood
Started by evergreen on Drying and Processing
Last post August 03, 2010, 10:58:40 AM
by gotwood
Can I use a burl wood for bracing and/or posts?
Started by esarratt on Timber Framing/Log construction
Last post April 15, 2015, 01:06:03 PM
by mrbrb
