Author Topic: HM126 band blade set and maybe switch to circle mill  (Read 1062 times)
Offline RAYAR
  • Retired May 2/19 more time to play with my mill
Re: HM126 band blade set and maybe switch to circle mill
« Reply #40 on: August 14, 2019, 02:17:52 PM »
Can you just add the shim to the hinge? Then it should still work for the other blades you already had.
I was thinking of adding it to the driven wheel, but looking it over again, will probably add to the hinge side, I can use two pieces of flat bar instead.
mobile manual mill (local build) (mods & additions on-going)
Shop built auto band sharpener
Husqvarna 50, 61, 254XP
96 Polaris Sportsman 500
2006 Ranger 4X2 w/cap, manual trans
Why are there more smaller Band Mill operators here then circle mill?
Started by MaddiesDad on Sawmills and Milling
Last post March 05, 2009, 03:18:06 PM
by TexasTimbers
circle or band mill
Started by jdw on Sawmills and Milling
Last post March 29, 2015, 08:25:25 AM
by Magicman
Circle saw edger mounted on to a portable band mill
Started by woodbowl on Sawmills and Milling
Last post September 03, 2005, 09:55:36 AM
by Percy
question
Chainsaw, Band or Circle Mill? Buy Build or Swap?
Started by Dangerous_Dan on Sawmills and Milling
Last post January 04, 2005, 09:49:30 AM
by doublecutusa
